Question about Watches
Bought TGHK WATCH MODEL # AW 91-750 LOST MANUAL. I CAN'T SET TIME, DATE, DAY OF THE WEEK OR THE OTHER THING. I'm screwed but I really like the watch & I went back to 3 seperate Wal-Marts & can't find another one like it. Can you help me with instructions on setting it? The only answers I've found so far are for time & date only. Any help would be greatly appreciated. Thank you, Ronda Lunny
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Posted on Jun 11, 2008
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Posted on Jul 30, 2008
SOURCE: GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Posted on Dec 19, 2008
  • 79 Answers
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Posted on May 15, 2009
SOURCE: can't set day and date on cote d' azur watch
Actually I can't solve this. My son bought the same watch on a Carnival Cruise and had the same problem. Upun closer inspection with a magnifying glass, it is obvious that the hands on the day and date dials are fake!! They are just attached in the center to the watch face. The other two push knobs on the watch also do nothing at all. So basically a rip off, but at least it was only $20. At least it keeps time for now. As usual, if it seems to good to be true, it almost always is. Sorry about that, but we are in the same club with you.
Posted on Jul 03, 2009
How to turn off chime on TGHK AW-77-004 watch?
Google (TGHK)(AW-77-004)(manual) without parens for instructions.
Nov 08, 2016 | Watches
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
I lost my manual for casiofishing gear aw82 watch. tell me how to adjust digital and analog time and date
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Nov 15, 2010 | Casio Fishing Gear Watch
Need to set time on WalMart TGHK watch.
If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
Jan 09, 2010 | Watches
How do I trun of the change of hour chime on my son's tghk watch
Press the bottom right button and while holding it down press the bottom left. All the days will show and the hourly chime is off, if the days aren't lit the hourly chime is off.
Sep 11, 2009 | Watches
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 | Watches
Watches Logo
213 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
