Question about Gateway GT5438 PC Desktop
Hi , I have a DX4822 Desktop... my problem is hi speed constant fan ...
  • 981 Answers
Noise, right? The fan tach transistor might have failed, but it's also possible that you need to dust it out and clear the ventilation paths; or that some knock jarred a heatsink off, which will need to be set securely back in place. Try swapping out the fan or running a fan control utility (or just the Intel utitlity for the chipset, or go update the Gateway BIOS and see what can't be done with that.)
Posted on Mar 13, 2011
How to increase rpm of processor fan
There is no way to increase a CPU fan's rpm. But you can try changing the settings in the BIOS on how it work for your PC.
You will have two options, first is SMART Fan which automatically adjust your fan speed depending on the load and heat of the CPU. Second is Always ON, which, as the name implies, makes your fan constantly run on the top speed.
Hope this helps.
Apr 30, 2011 | HP Pavilion dv6000z Notebook
Need to know what the four wires are for, red black yellow and blue, I am wiring it to and ancient apple, no choice. just need to know how to set it up at hi speed constant operation. I am using a rf-120...
Usually the red is +12 volts DC, the black is ground, the yellow is the tach sensor, and the blue is speed control. The fan will run at full speed off the red and black. The yellow and blue are of no use unless the motherboard is designed to use them.
Mar 29, 2011 | Rocketfish Gaming 120mm Case Fan RF-120FAN...
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
My computers cooling fan keeps speeding up and slowing down is that a good thing or a bad thing
I'm assuming your desktop has an AMD processor?
AMD have a process called "quiet and cool" this basically speeds up the fan when the processor is under load and getting hot or slows it down when the processor isn't working as hard.
Regards
Mike
May 26, 2010 | Dell Inspiron 531s Desktop Computer
I recently had a new power supply installed in my compaq presario SR1318NX, now the fans run almost constantly. The air from the fans does not feel hot, nor does the tower. Is this serious?
In a desktop computer the fan is supposed to run constantly otherwise the processor would get that hot the system would repeatedly shut down or even damage the processor or motherboard.
If the fan is noisy then chances are that the fan blades need cleaning of dust.
Other than that you have nothing to worry about.
Regards.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
The fan on the motherboard runs at full force constantly. Any ideas?
This is a common problem for Gateway. The first thing to do is shut the computer down and blow out the dust from the processor heatsink and other areas that it is heavily collected. Then go to the Gateway website and download the latest firmware for your computer. They constantly have fan issues. These are almost always addressed in firmware updates from the manufacturer website.
Oct 19, 2009 | Gateway 3200SB (521563) PC Desktop
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
Main fan on dell dimension e521 on full blast when comp on
Do you have your PC in some sort of enclosed space with little ventilation? If so, the constant fan activity is your PC trying to keep things cool inside. With little ventilation comes great heat, and PCs like it cool.
Dec 27, 2008 | Dell Dimension E521 PC Desktop
PC Fan Issues
1 fan in and 1 fan out, usually out through the front.
Aug 27, 2008 | Gateway 506GR PC Desktop
High speed fan
Well it may just be a program has set it and hasn't set it back... You can use a program called SpeedFan to "Control" ya Fans here ----> www.almico.com/sfdownload.php
Aug 20, 2007 | Gateway 830GM (RB830GM) PC Desktop
Gateway GT5438 PC Desktop Logo
207 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
