Question about LG GSA-H55N DVD-RAM Burner
Sometimes it doesn't read CD and DVD, often doesn't recognise any CD Or DVD inserted in even its driver. THANKS for helping me!
    President:
  • 1,768 Answers
1. When an optical drive doesn't read or recognize CD/DVD the unit is in need of replacement. Units can be straight out of the box and fail.
check the connection to the device ( cable) and the power to the unit
Posted on Mar 13, 2011
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
Hi! I have a webcam easyCam Pro HO98669 Ver.1 and my computer doesn't recognise the cd with the driver. What can I do?
Ok it isn't unusual for a CD ROM or DVD ROM to not recognize a CD or DVD insert to it..Ok try this clean the lenses of your ROM using a CD or DVD cleaner disc if you have also try to wept your cd software with a clean dry soft cloth or cotton..If this will not work perhaps you need a new installation cd for your webcam.
Jul 10, 2011 | GE EasyCam Pro Webcam
Does not recognise a disc when inserted
tery using an IRIS cleaner disk
Please rate the help++++Thanks for using FIXUYA
Sep 27, 2009 | Pioneer DVR-112D DVD RW Dual Layer Burner
Plz help me out with serious problem of cd/dvd drive
it looks like you need an update for your DVD driver (Optiarc drives )
use the lenovo support site to get the latest driver for your notebook,
http://lenovo.com/us/en/index.html
this should solve your issue.
Sep 06, 2009 | Lenovo 3000 Y410 Notebook
My pc recognises my dvdram as cdrom, after re installing.
try removing it and then switching on computer make sure the icon has gone, restall and recheck icon. this sometimes works most of the time.let me know how you get on.                 mister dj
Jun 01, 2009 | LG (DAD-8020B) DVD-RAM Burner
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My Lite-On Internal Dual DVD does not recognise any CD. It keeps asking to insert a disc in my destination drive. It does however, recognise a DVD. My checks conclude that it's the best available...
Try a 'quickiee', While the power is OFF! disconnect the cables or cable to the duel dvd,[IDE (long 26 pin) & power] turn on computer, goto to control panel >system icon>system properties>Hardware>device manager>DVD\CD-rom Drives. NOTE:: you should see ONE instance of your CD\DVD drive, REMOVE it.Turn computer off., RECONNECT the power & ide cables to the dvd. Turn power on, the computer SHOULD see your hardware, if it don't, It could be semi-damaged,or internattance [sometimes is, sometimes not working]
Apr 20, 2008 | Computers & Internet
Philips CDD4851 CD R/RW in my HP Pavillion XT963
if the device is being recognised, As D:- Or E:- et,c.
right click on the device, and select options from there.
such as open/explore et,c.
If the disk has been written to in any way shape or form, even the smallest file. then the disk being read will be classed as empty.
try a different CD Disk, And try re-installing your CD writing software.
Hope this helps mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Read only cd-r not dvd
Have the same problem, it used to work and suddenly it wont do it anymore. I guess this is due to windows XP updates. Windows says that the driver is up to date and I also installed the latest firmware. I am using Nero 7 to burn. I had troubles before but somehow fixed it. Now when I insert a DVD (data) and try to open the dvd drive the whole computer hangs. The content shows for a moment before the computer freezes so it IS in the DVD.
Oct 13, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
LG GSA-H55N DVD-RAM Burner Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
