Question about Dishwashers
Hi. we have W'house 905 dishwasher. Have had the element replaced. It gets to half way thru cycle then cutes out. Cuts off all electricity in the house. Restart again gets to half way then cuts electricity trip switch. Is ther an answer? Tks.
  • phil281 Mar 14, 2011
    Hi Daniel.
    Thanks.but ..no go Im sad to say. I have been told to eliminate the wires that control the 'Hot' wash part of the cycle and just use as a 'cold water dishwasher' is this correct?
    Tks
    Hi
    The dishwasher keeps cutting out after about 10mins into the cycle. It sometimes trips the breaker.
    Not overheating then , If I leave it for a while I can reset it and start again but it will cut out again.
  • 4,323 Answers
Hi
This is happening due to shorted wires or worn out wires connected to the element. It may also occur if you are not using the model specific part as replacement. Please get the element checked again for any cut or loose wires. Hope this helps... Please post back if you need further information.
Daniel
Posted on Mar 13, 2011
  • Daniel Scott
    Daniel Scott Mar 14, 2011
    Hi
    Does eliminating the wires to 'Hot' wash part help you? If no then it is an issue with the wires shorted inside the dishwasher. The circuit breaker trips when the current drawn by the dishwasher is more than the expected limit. I would suggest you to check shorted wires or worn out wires connected to the element.
    Daniel
Westinghouse dishwasher sb916sk runs 22 minutes then cuts power
Is it on a dedicated circut? A dishwasher needs to have a 12Ga two conductor with ground line that is dedicated to ONLY the dishwasher and possibly share with the garbage disposal.
Also, it should be on a 20 Amp breaker.
Mar 11, 2014 | Westinghouse Dishwashers
Whirlpool dishwasher stuck in cycle
I found this:There are are 2 stats, hi limit and operating. You should find them attached to the pump housing. It gets a little tricky but the problem will boil down to one of the stats is bad or the heating element itself is bad [or something like a wire burned off at the element which will be obvious]. It can get a little tricky. I would start by checking to see if the element gets hot during operation. If no, ohm test the element itself. If ok, ohm test the high limit stat, it should be closed at room temp. If ok, try bypassing the operating stat and see if the element now gets hot during operation.
Read more: http://www.doityourself.com/forum/kitchen-laundry-large-electric-appliances/386770-whirlpool-dishwasher-gets-stuck-cycle.html#ixzz1kDTDjTm7
Jan 22, 2012 | Dishwashers
They heated dry cycle is no longer working on my General Electric PDW8200J03BB Dishwasher
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
May 18, 2011 | GE 24 in. Profile PDW9280JSS Built-in...
Runs thru cycle but no heat . Exaust air is cold. All filters are clean
first make sure you have 240volts at the plug,if not check homes fuses or breaker to make sure they're good and/or not tripped,then remove either the top and front cover,or if the heating element is accessable from the rear do that,if the elements ok then check the hi limit thermostat on the element housing,then check the thermal fuse and cycling thermostat/switch on the blower housing,if any of these open you wont get heat
Oct 24, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Wont turn on changed thurmal fuse. worked one load than blew agin.
if your machine is running extremely hot,check for proper exhaust from element housing thru blower wheel housing all the way to the outside vent pipe,any lint will impede air flow and can cause this condition,then replace the dryer cycling switch as it may be getting erratic and not cycling when dryer is hot enough it is located on the element case along with the hi-limit thermostat,replace them both
Jan 25, 2010 | Kenmore 62802 Electric Dryer
I have a Matsui MS2SA dishwasher doesn't heat or change program
Spraying WD40 into electrical circuitry is a sure way to cause failure.
Mar 01, 2018 | Dishwashers
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
My westinghouse 905 dishwasher starts ok but stops somewhere in the cycle, not having washed the dishes properly.
Hi. I have a Westinghouse 905. At first all ok then we found that it cuts out and short cicuits the whole house. Trips the electricity switch. Restart gets to about half way through then same thing happens. Any help please?
Tks
Apr 22, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
