Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
My CPU will not turning on but has a one beep sound, when i start 2 open then automatic of?
    President:
  • 1,768 Answers
1. Your issue is possibly the power supply
2. You will need to have the PX serviced and the power supply replaced.
3. this also can be the CMOS battery > could be low and needs replacement ( located on the mother board.
You didn't indicate how many beeps or give more details as to what is actually happening.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for you Problem
Thank you Fixya Expert.
Posted on Mar 13, 2011
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
2 short 6 long beeps, whats the problem? nothing on screen, no other signs.
Check your VGA Card it's properly connect and your memory module, maybe one of that is not functioning.
If still have that beeps then change temporarily your VGA Card with another. As long as you see some appears on the screen then it's good luck.
Please rate us!
Oct 05, 2009 | ASUS p4p8x-uay Motherboard
Pc not working
There's a chance that it just overheated and the cpu automatically shutdown. This could be caused by a number of things, including a defective fan or an accumulation of dust. you might try opening up the case and blowing out the dust. If you've let it cool and it's still not able to turn back on, you might have to reset the bios on the motherboard to get it start back up.
Jan 31, 2009 | Intel Motherboard
Starting problem
check the processor fan is working or not. check its connector. Also check if there is any beep sound.
if processor fan is ok then disconnect all the cables, data and poewer cables. plug the power connector to motherboad only and listen if there is any beep sound there.
tell me after doing this, if problem doesnt solve.
regards,
Jul 27, 2008 | Computers & Internet
Wont start
open the side casing of your cpu then try to switch-on, if you notice that the fan of your cpu rotates, the hdd led is lightng, the power-on led also lit then you heard a beep (one) sound there is no problem but your video card connection just loose
Jan 10, 2008 | Computers & Internet
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
Asus P4pE not booting.
The beeps you hear are probably BIOS error beep codes. Through a series of long and short beeps the BIOS communicates what type of error is occurring during the initial stages of the start up process. If you can tell me the manufacturer and model number of the board AND the sequence and length of the beeps I can point you in the direction to go.
Dec 13, 2006 | ASUS P4PE Motherboard
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
54 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
