A voltage was put in to the Ear Phone port and it started flashing
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
Chek it's surkit and conection........
Posted on Mar 13, 2011
Will not work with turtle beach x11 head set no mic...
take your cell phone ear piece and mic attached cable and clamp the mic part with the clamp that is on the cable to the end of the turtle beach mic piece just before the foam cover with the cell phone mike facting toward you. plug in the cell phone ear piece to your left ear and then put the tuttle beach head set on just a normal. the cell pone ear piece is so small that you will not even know it is there when you cover it with the turtle beach head set. plug in the cable from the cell phone into the port in the rear of your turbo fire two controler and away you go. you can enjoy the great sound of the turtle beach head set and at the same time chat with the cell phone mike. you can adjust the sound level on the head set but you will not be able to adjust the volume on the cell phone mike. but it works fine just place the head set mike boom real close to your mount so your friends can hear you well. I use it in two worlds two in the marshlands while leveling up on x box live. you can find me a DeepReserve which is my game tag.
best,
Jun 28, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
Hi. I am being faced with a recurrent problem. Again and again, the speaker in the flap stops working. so then i have to put on the speaker and talk. I showed the phone to a mechanic, they changed the ear...
the speaker in the flap stops working. so then i have to put on the speaker and talk.I showed the phone to a mechanic, they changed the ear flap with the ear piece but it worked fine for a few phone calls only.Kindly advice.
Jan 24, 2011 | Motorola Mobility A1200
1989 Jeep wrangler getting fire to coil after replacing the crankshaft censor now but still not starting .
make sure that you are getting fuel to the motor.guessing that its a 4.0 i6 motor,check the fuel pump by haveing some 1 turn the key on while your under the gas tank near the pump.if its a really quiet pump u might have to put your ear to the tank.If it turn on the u need to check to see if fuel is getting to the fuel rail,should have a test port on it,that looks like a very short valve stem for a tire.turn the key on then check if it puts out fuel through the port.if it does then you need to see if your injectors are getting voltage.
Oct 23, 2010 | 1989 Jeep Wrangler
My ear phone audio out put not working
Back or front of the PC??
If rear ensure its plugged into the green socket.
Do speakers work out of this port??
Mar 24, 2010 | Computers & Internet
No sound--master volume says ear jack
i put it in the freezer, hit it, drove a nail into the earjack port. then i poured water into the earjack port, held a lighter to it, and blew into it, none of that worked, so i jammed a paper clip into the earport and that fixed it. i also slammed in on the ground a few times.
Mar 02, 2010 | LG VX5500 Cell Phone
94 Altima, drivin along, just lost power, still had radio & lights, will turn over but will not start
Very good possibility that the Fuel Pump has gone out.
Find the Fuel Port on the Fuel Rail going to the Fuel Injectors. Remove the cap. Pack plenty of rags or paper towels around that area. Wear goggles to protect your eyes from Gas Spray! Using another wadded rag or paper towel partially covering this port and a small screw driver - depress the stem inside this port. Have a partner turn the Key over attempting to start the vehicle. A strong stream of gas should come out.
If no gas is coming out: check the Fuel Pump Relay/Fuses. Use a Voltmeter to check for voltage at these locations. The reading should be 11+ to 12 -volts.
If there is Voltage: Again with a partner behind the wheel, remove the gas cap. Place your ear up very close to the Gas Filler Tube (where you put gas in). Have your partner turn the key over to the On (not Start) Position which is the position just before Start. You should faintly hear the Fuel Pump humming. Have your partner turn the Key to the Start Position, again you should hear a very faint humming (over the car cranking).
If there is not indication of humming: Jack-Up and properly support the rear of the vehicle with jack stands. Once again with a partner behind the wheel: go under the vehicle and place your ear up close or on the gas tank. Have your partner turn the Key to the On Position. You should hear the humming.
If not, have your partner turn the Key to the Start Position. There should be humming.
If no humming there is a great chance your fuel pump has gone out.
Based on your year (1994) this is highly probable.
HOWEVER: If there is humming, change out your Fuel Filter and recheck for fuel at the fuel rail.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at Fix Ya.com!
Feb 26, 2010 | 1994 Nissan Altima
How do i connect phone with m2300 ear piece
Begin with Headset turned off. Press button for 6 sec. Release button when Light Indicator flashes blue and red. Headset is ready to pair with Bluetooth device. Use your device?s menu to enter pairing mode and select ?320 Plantronics? on the display. When asked for passkey, enter ?0000.?
Mar 28, 2009 | Plantronics Explorer 320 Wireless Headset
Mp3
Have you reset it? Grab a needle or a end of a ear-ring and put it in the hole located right of the ear phone jack, once you hear a button being pressed down, hold for 5 seconds and then it should turn on. As for recongnization, try different USB ports on your computer.
Mar 12, 2008 | Memorex MMP8565 MP3 Player
Use of ear phones to listen to music.
IS LOCATED ON THE LEFT SIDE OF THE PHONE BELOW THE MICROPHONE LOGO
Feb 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
