Question about MSI K8MM-ILSR (MS6741030) Motherboard
When I boot up the computer all i get is the msi CoreCell logo on the screen and it never boots up. Can't use del or any of the other commands to get into the bios.
  • Christopher Will Mar 13, 2011
    Is your PC speaker connected? Does it make a series of beeps when it starts? Also, can you view the POST as an option when you are booting it up?
    President:
  • 1,768 Answers
1. your issue sounds as if the mother board and or the power supply needs replacement
2. this PC possible need service.
3. there could be a hard drive issue also.
Posted on Mar 13, 2011
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
Msi mini laptop
your master boot record MBR is damaged and your harddisk looks missing or blank to boot up. run cd and go to command prompt.
In black window were :>chkdsk c: /f then press enter. type as shown from prompt with space between k c and : /...
Aug 18, 2013 | MSI Wind Computers & Internet
How to Enter Bios for MSI A6400 Laptop?
Press Del while the Press DEL to enter SETUP message displays on screen after powering on the computer. SETUP, in this case, is the BIOS.
Jul 27, 2013 | Computers & Internet
How do i set my laptop to booth from cd/dvd?
There are 2 things you could do. 1) you can change the boot settings in the bios or 2) you can choose the the boot device on the logo screen or bios screen on startup. to do #1 you need to press either DEL or F2 on the logo/bios screen. inside you can change the boot priority. for #2 once you see the logo/bios screen you can either press F10, F11 or F2 to go to the boot device selection. To know which buttons to press for these once you are on the bios screen the right button will be flashed.
Jun 06, 2012 | Computers & Internet
What will i do!after i shutdown my compaq Evo N800v laptop,and remove the harddisk for me to copy some larger files on my another laptop!and when i put the harddisk back and power it on,it just hang up on...
It looks like one of the start up files have been changed or corrupt. Any change to the boot environment will cause this problem. The solution here could be a bit long but you just have to take your hard drive to the other computer and back up all your user data and files you need. Then take is back to the Laptop, just in case anything goes bad. Get a copy of the operating system you are using on a CD and let the computer boot from it by pressing F2 or Del to get into the BIOS and go to the Boot Sequence or Boot order to make the CD rom the first device to boot from. Then press F10 to save and exit. This will allow the computer to boot form the CD. Choose the repair option to repair the master boot record. If you are using Windows XP, put the CD in and choose Repair on the first window. This is a command prompt and this is what you are going to type in the command prompt to install the Automatic System Recovery (ASR) winnt32.exe /cmdcons and this will install the recovery console. In the recovery console, type fixmbr to fix the master boot record
Feb 22, 2012 | Compaq Evo N800V PC Notebook
No arranca windows por el problema de windows root\system32 \hal.dll.
Hi! Welcome to www.fixya.com.
You need to get an Windows Operating system XP
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini DEL C:\Boot.ini BootCfg /Rebuild Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
TIP: Recovering Windows XP using the Recovery Console
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | MSI Wind U100-030US Laptop
I can't enter cmos althouh i press del or f2 when i press del ,next screen appear blank with cursor. will this problem solve by upgrading bios?
Restart your computer do you see prees f2 or something else
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Jul 03, 2011 | MSI PM8M-V Motherboard
For MSI U160 netbook On power up goes to MSI screen with Press DEL key to run setup Press F11 ... Press F3 ... Does not respond to any of the above keys, will not depower and this screen remains...
none of these are of any help... the only way I have found for my computer to boot normally is with a live linux usb and let that take me to my original hard drive. As in I put the usb in, boot up, brings me to live usb prompt, I do nothing until it boots from hard drive and I'm stuck scratching my head at why this works.
Mar 29, 2011 | MSI U160-472US Netbook
When i switch on computer ACER logo appears with message along bottom of screen Del: Enter Set-up F12 Boot Menu Computer is frozen, cannot go any further
Press Del - you will enter the BIOS - in there check that the hard disk is recognized and the boot order is as follows: 1 cd-rom, 2 hard disk.
If everything is ok but you still cannot boot in Windows then it has been corrupted. Recover your files using a Linux Live-CD like  http://pclinuxos.com/  and reinstall.
Jan 21, 2010 | Audio Players & Recorders
Have a friend that can't boot his computer to windows xp
Before trying to use any of Dell-net's suggestions, we've got to get you into the bios.
It looks generally like this:
You should see a message displayed when you start the computer that says press "Del or F2 or F10" to enter setup.
Once we get here, we can proceed.
Mar 10, 2009 | Compaq Presario 3045US Notebook
MSI K8MM-ILSR (MS6741030) Motherboard Logo
95 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
