There is no bios update for this model. there should be no problem installing 64bit windows 7. The athlon 5200 is a 64bit chip so there is no problem there. If you cant install and you think its bios related then reset the bios by either shorting the rtc pins or remove the battery and refit after 10 mins. make sure you reset the bios back to defaults before you make any changes to it.
Make sure your FSB(FrontSide Bus, aka 'CPU External clock is set to 166MHz both in BIOS and via jumper on your motherboard - refer to your manual for details. i should be jumpered accordingly.
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details: Motherboard manufacturer's name: ASUS A8M2N-LA HP/Compaq name: Nodus-GL8E CPU/Processor Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors Front-side bus (FSB) 2000 MegaTransfers/second Chipset GeForce 6150 LE chipset BIOS features Award brand system BIOS Keyboard combination to used to enter BIOS: F1 Form factor Micro-ATX: 9.6 in X 9.6 in Memory Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB* PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
If the web site for this motherboard does not have a bios update to run this cpu then there is no bios. It might not support Phenom or higher
this is a link to the download and your bios is the last update http://support.acer-euro.com/drivers/desktop/aspire_m5100.html
So just because some one said "update the bios" doesnt mean there is a bios that will run it , I believe that this board will handle a 6000 x2 and that is about it. Sorry hope this clears things up for you
