Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Hi, my camera was working fine and then in between taking pictures all of a sudden it said "memory card error" and now I can't see some of the pictures I took. Please help!
    Problem Solver:
  • 8 Answers
First don't not take any more photos on the faulty memory card!Do you have a second memory card? if so does the second memory card work?. If the second card works you could try some file recovery software. I use one that came with my, but you could try http://www.z-a-recovery.com/digital-image-recovery.htm ( I have never used it but does have a free image recovery option).
I have managed in the past to recover quite old files from memory cards, the important thing is to not add any more data to the card as this can overwrite what is already there. Unfortunately there are no guarantees for data recovery. Hope it all works out
Posted on Mar 13, 2011
  • 2,574 Answers
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
Oct 24, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
Sanyo VPC-T700 Memory Card Error. All of a sudden the camera is displaying "CARD ERROR" message. Camera works fine witout a card installed. Help me please
Hello Karen,
Please look for lock in memory card as in the above image. If the white latch is in downside position then slide it in up position. Also check that you are inserting the memory card in right position in the camera.
Jul 03, 2011 | Sanyo Xacti VPC-T700 Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Hi. I have a 16GB memory card. I checked it several times with h2testw software and it's working fine. After I shoot about 4GB I start getting "unidentified image" when I try to see the...
The canon PowerShot SX210 IS only supports memory cards up to 4GB in size. Larger ones will work, but because of the format type the camera uses, it won't be able to read correctly past 4 GB.
May 05, 2011 | Canon PowerShot SX210 IS Digital Camera
My 4gb sdhc memory card has been working fine in my Nikon Coolpix camera for the past 3 months (while i've been studying abroad). i was taking pictures today and all of a sudden my camera read that...
ok hopefully just a temporary problem for now but you really need to take the card out of your camera and plug it on another device like a computer and then before you open the folder from the card you should click on the properties tab to check if you can see the space taken from the pictures if not then sounds like the memory card has lost the internal contact and usually is not repairable!
if you can see that the card has just got some espace left then all you need is software to back up the card which then you can see the stuff providing is not corrupted.
Yes I know there is no really a solution in my answer but cards/drives are very sticky either work or not!
Anyway hope you can back up all your pictures
Nov 27, 2010 | PNY 4GB Secure Digital High Capacity...
Memory card locked on canon A470 digital camera
take the card out of the camera and look at it closely. You'll see the LOCK switch.
Mar 24, 2009 | Canon PowerShot A470 Digital Camera
PNY 2 GB SD memory card problem!
first format the card once, there may be any corrupted files over there.
If this did not will post another solution for this.
Jan 05, 2009 | Kingston 1GB Secure Digital Memory Card
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
180 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
