Question about Toyota Car Audio & Video
Cant work out what wires are what have test light on them wired it up and it still doesnt work. looked on the interenet for wiring diaphrams and comes up with something different and wired it up like that but still doesnt work. what to do?
Ultra mp3 code
Posted on Mar 13, 2011
I have a 2001 olds aurora, wont start. Doesnt click or nothing, tried jump starting it dont do nothing. Battery is only 2 years old.
when you turn key on is there power to lights radio dash ? if yes check the starter relay and solenoid you can check easily using a test light find a good ground and a test light that works test light on battery first at the starter there will two wires one thick and will lead to battery the other wire is thin this is the wire you want to test have someone turn key to start while you test for power at wire if there is power at the wire replace starter the solenoid is deffective if there is no power at the starter sol wire then check starter relay
hope this helps leave me a comment and vote this was helpful any more questions reply
Jan 17, 2011 | 2001 Oldsmobile Aurora
I cant get both switches to work properly one minute it turns the light on the next they done work. is the red wire suppose to hook up to the black screw
The key to three-way switches is the dark screw.
And different brands of switches put dark screw on different side of switch.
So, lets get out of this mess with a bit of testing.
You have two switches with 3 wires on each switch for a total of 6 wires.
Take out both switches and separate wires for testing.
Turn on power and test each wire to bare copper wire.
One and only one wire will test Hot.
The hot wire goes to dark screw on switch1.
The other two wires in that box go to either screw on switch1.
One switch done, one switch to go.
Move switch1 lever to down position.
Turn on power and test 3 remaining wires.
One wire will test hot. Mark this wire.
Move switch1 to up position, and test 3 remaining wires again.
A second wire will test hot. Mark this wire.
The 2 marked wires attach to either brass screw on switch2.
The third wire attaches to dark screw.
Both switches done.
Nov 19, 2010 | Pass & Seymour Trademaster 3-Way 15 Amp...
SemiTrailer Wiring when I turn on my left turn signal all lights blink.
sounds like if its a 2 filiment bulb(1156) one of the filiments is touching the other and back feeding the signal,start by removing all signal bulbs and replace each with a new one as a test,also reground all grounds,if the signal cant find reference ground it will take the next path to find it,if this doesnt work then possibly you have wires in the frame bare and touching
Mar 18, 2010 | 2004 Dodge Ram 1500
1989 chevy k1500 electric passenger window not working
I sounds like it might be a window switch that has gone bad ck the connector at the window motor by connecting a test light across the 2 wires operate both window switches the test light should light If it doesnt then connect the test light to a good ground and back prob the connector on either wire and operate the switch in both directions the test light should light In one position of the switch then ck the other wire the same way and the test light should light up with the switch in the other position (down up) wich ever wire the test light does not light up on needs to be cked for a break. The wires in the the door pass through (the rubber boot that goes from the door to the body ) can break pull the boot loose and pull the wiring out as far as possible to ck for broken wires.
Mar 08, 2010 | 1990 Chevrolet K1500
97 toyota tercel cigarette lighter does not work. fuses look to be in good shape. any ideas?
get you a test light. pull the plug out where you can see the leads. the red one in the center is your hot wire. touch it with the tester, the other wire on your tester usually with a clip to a good solid gound. if the light doesnt come on then reverse test leads and try again. by doing this you will determine if its a ground wire not getting to the cig lighter or is something is wrong with your hotwire.
Aug 19, 2009 | 1997 Toyota Tercel
Mower wont start
Solenoid has dead short. Replace it. Cost is low. Crossing terminals on today's engines with electronic ignition parts is dangerous to the other parts.
May 24, 2009 | Mtd Garden
Driver side turn signal light doesnt light up, you can hear it bl
This problem is either a badly corroded light socket or a wire fault. Look for green deposits in the sockets... if they are clean then use a test light to check for power with the blinker on... if still no power then it's a wire fault (short)... Hope this helps...;-)
Apr 14, 2009 | 1995 Honda Passport
Amp doesnt power on no lights or anything
To test if the amp even turns on take the amp and three wires (does not matter what guage) and connect it straight to the battery. Two wires (one for the power and the other one to the remote) and the third wire goes to ground. This will verify that the amp does in fact work. If this test fails then something has happened to the amp. If the test passes and you see that you do have power to the amp with this test then you know that you have a wire issue. Trace out your wires and make sure that you have a good connection throughout the car. This should fix the problem
Mar 16, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Car Audio & Video Logo
26 people viewed this question
Top Toyota Car Audio & Video Experts
Martin Clarke
Martin Clarke
wadingriver
wadingriver
Are you a Toyota Car Audio and Video Expert? Answer questions, earn points and help others
