Question about Intel D845GLLY Motherboard
Beep after every 10-15 seconds, no display - Intel D845GLLY Motherboard
    Sergeant:
  • 154 Answers
Depending on the beeps, it can mean different things.
The most common error is because your RAM sticks are loose. If you are proficient in operating PC hardware, open your case, remove the RAM sticks, brush the contacts slightly for dust, and put them back in, lodging them properly.
If you aren't sure of what to do, ask someone whose down this before. You dont want to pull out the wrong components.
Posted on Mar 13, 2011
How to correct error code 4 in 10 on Sharp pocket computer pc-1270
I found the answer for the PC1500, and I'm guessing the error codes for the PC1270 will be similar. Here is what the manual says:
This error occurs when there is no DATA corresponding to a READ command, for example:
10 READ X, Y
20 DATA 10
30 END
The display will say, "ERROR 4 IN 10"
The solution is to provide enough DATA to satisfy the READ. For example, change line 20 to read as follows:
20 DATA 10,15
Hope this helps.
May 04, 2017 | Sharp Office Equipment & Supplies
Tip
Playstation 3 no display?
Have you changed from A/V to HDMI and now cannot get a display?<br /> <br /> Playstation 3 not showing video but playing sounds?<br /> <br /> Follow these very simple steps to bring your Playstation 3 back to life!<br /> <br /> <u>Step 1.</u><br /> <br /> Turn the Playstation 3 off into standby mode (red light on)<br /> <br /> <u>Step 2.</u><br /> <br /> Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep<br /> <br /> <u>Step 3.</u><br /> <br /> Wait for the Playstation 3 display to initialize.<br /> <br /> Your Playstation 3 should now display properly and you can get back to your gaming!<br /> <br /> Hope this tip helps you out.
on Nov 10, 2010 | Sony Playstation 3 (PS3) Console
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
How do i reset the sid display in 2008saab93turbo after replacing battery
pressing the CLEAR button for 8 seconds. on older 9-5 and 9-3 SID's, that you must press CLEAR once & release, then press CLEAR a second time, and hold for 8 seconds. While holding down CLEAR for this second time period, at the 4 second mark "CLEARED" will be displayed, and you will hear 1 beep. If you release the CLEAR button at this point, the DTE and MPG will be cleared out. If you continue holding the CLEAR button past the 4 and 8 second marks, you will hear a 2nd beep, and "SERVICE" will be displayed. This now means that you have cleared and reset the Time For Service message.
Dec 01, 2014 | 2008 Saab 9-3
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
Wont come on
One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard / Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
Oct 03, 2009 | HP Pavilion A1245C Athlon 64 3700+ DVD+RW...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Motherboard
TAKE YOUR DDR CARDS OUT ,, AND SWITCH THEM,, ,,IF THAT DOESNT WORK TRY WITH ONE AT A TIME,, GOOD LUCK
Oct 05, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
Intel D845GLLY Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
