Question about Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System
How do I un mute the pack - Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System
  • Sennheiser Master
  • 5,603 Answers
It looks like the mute function is only available from the menu... not very user friendly at all... I guess they figure the performer doesn't need to mute easily or quickly... Volume control I suspect is all that is readily availab;le at the pack to quickly mute.
Posted on Mar 14, 2011
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
Crate csx24 sound board- the mute lights will not light. Sound works but lights will not light.
USUALLY the Mute LED's for the switches ar operated by separate contacts on the mute switch an a resistor current limit for the LED. I could NOT find the schematic for this board, HOWEVER some Soundcraft brand mixers do NOT have illuminated Mute switches... Not sure about your particular unit.
Aug 04, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
No playback coming out of speakers or headphones. Cannot find anything wrong with the program or the hardware.
Make sure in the PC "control panel" Sounds and Devices all the sources and outputs are set to the hardware you are using instead of the default PC audio board. Also check they are un-muted and volumes are up.
May 10, 2011 | Propellerhead Reason 5
I have a Behringer sx3242fx, mono input channel #2 mute button got stuck in (pressed in), i.e. the channel cannot be un-muted no matter how it is pressed. Any suggestions?
Put a tiny bit of CRC226 around it to lube the button. Then CAREFULLY use a scalpel to encourage it to come up. Then put a little more 226 around it.
Mar 28, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
The ew 3000 iem (brand new) is stuck on mute. Tried everything to no avail. Ideas????? Please Help!!!???!!!!
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards, Tony
Mar 24, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Trying to find the mute j111 on xr684f
I don't believe there is a mute function on the XR684F unit. There is a mute on the XR8600 but they probably use different boards in it. The mute button for the XR8300 and XR8600 are near the effects selector button and LIKELY is board mounted and would not have a J111 connector. If the electrical function is in the XR684, it MAY just be pads like test points, to only be used during testing and troubleshooting.
Mar 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
If the master output lights go above green (into yellow) the sound becomes slightly distorted even at low speaker levels. i have cleaned the output jacks but it is still distorted
Does the distortion ALSO appear when you listen with headphones? If not, the problem may be downstream. The driver for the mute control line to the mute transistors may have a problem. Make sure the mute is off.
Nov 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System Logo
1,160 people viewed this question
Top Sennheiser Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Music Expert? Answer questions, earn points and help others
