The PT-61LCX65 bulb I installed on my Panasonic TV gives off a hot smell. Why is this happening?
    President:
  • 1,768 Answers
1. the voltage regulation circuit to the luminous bulb has failed
your unit needs service before it gets to hot and catches fire.
A qualified tech will determine replacement to the bulb and components.
Posted on Mar 13, 2011
Panasonic pt-61lcx
The lamp will not cause this issue.
sometimes if set is not level or supported all the way across at the bottom the picture will be tilted.
Jun 13, 2012 | Panasonic PT-61LCX65 61" Rear Projection...
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 Bulb Reset
hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
Sep 17, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Most likely the lamp will correct this issue.
Apr 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
