Cant get no data on scaner - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
The drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps don
Posted on Mar 13, 2011
Scaner motor doesnot stop
If your scaner motor continues to run or skip while the unit is first powering up there is a problem with the comunication from the scaner to the main system board in the back of the unit. This is not an issue that can be resolved with out voiding any warranty since you will have tp remove the back plate of the printer. Most common causes bad scanner motor, dirt or toner dust in the conections to the main board, or a damaged data cable(silver).
Sep 10, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Hello, i have printer@scaner epson tx100. but i cant make the scaner work. i tried a lot of times to load the drivers, my printer is working, but scaner dosent! my computer do not recognise it!
lapinskyi,
If you are loadiing them from a disk I have a tip at http://www.fixya.com/support/r7723090-setup_all_in_one_printer_scan_computer which tells how to do that or better yet how to download and install the latest drivers from the internet.
Thanks for using FixYa and for the great rating.
hardrocko
May 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I am install the driver for the scaner but i cant see the scaner on xp pro
Revisit the Xerox website www.xerox.com and search for drivers and reload all the drivers you need, again.
Good luck.
Jan 16, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
I have a epson dx4050 and i cant figure out how to scan with it
usually ..if it is a scaner when you install it it shoud have a software for scaner ..you have to power the scaner ..put the document or picture in ..after that open the scan manager or whatever the software that came with is named..and look for a button scan ...it will scan ..and when it finishes it will open the containing folder..and show you the job s done...usually like tumbnails...this can be opened in full image ...copied..or cut ...or whatever ..they usually remain in that folder for future use..unless choose to delete ..
Jan 30, 2010 | Office Equipment & Supplies
Scaner won't power up when pluged into dlc
Fuse #5 10A Data Link Connector (DLC)
located in.
Passenger compartment fuse panel
The fuse panel is located on the left
hand side of the instrument panel
facing the driver’s side door. Pull the
panel cover outward to access the
fuses
Jun 02, 2009 | 1999 Mazda Pickup
Having trouble with my knew uniden scanner
first you sec that your scaner data in cable is USB or OTHERS then you took a data cable and conect your scaneer your pc when you conect your data cable in your pc then you sec that your pc gave you amasage like that : FOUND NEW HARDWARE: then you put in your scaneer instollation disk your cd rom and instolle your scaner driver properly and use it isely.
Jul 14, 2008 | Office Equipment & Supplies
Scanning
can you be a bit more specific?
do you have the scaner connected to your computer? do you have the drivers of the scanner? what kind of scaner is it?
Dec 06, 2007 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
