I have a series 8000 model number 6LSP8255AWO. Is there a filter on this machine?? I am having trouble with every wash as it leaves Lint on certain fabrics. It is almost as if a tissue has gone through the wash.... but it has been happening for a couple of weeks and we keep re-washing our clothes.. any ideas would be great..
jsrock516
  • 5911 Answers
SOURCE: Washer leaves too much lint on clothes
There are many things that cause lint. Some are easy to figure out, some aren't. Here are some of the most common things: 1. Separate clothes that are lint givers from lint takers (i.e., sweaters are lint givers and should not be washed with cotton which attracts lint). 2. Check clothes pockets for tissues or paper. 3. Don't overload the machine. 4. Use enough detergent to hold the lint in suspension. Read the recommended usage on the detergent bottle. 5. Use enough water to rinse the lint away. Washing large loads on a water saver mode is not a good idea. 6. Use fabric softener to reduce static attraction of lint. 7. Washing clothes on too long of a cycle, too often can cause premature wearing of the the fabrics. I hope some of this may help you. PS Adding a cup of plain white vinegar to the rinse cycle has also been known as a "cure" for controlling lint.
Posted on May 22, 2007
  • 105 Answers
SOURCE: Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Posted on Mar 16, 2008
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
  • 14 Answers
SOURCE: can't find the lint trap
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open).
Posted on Aug 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Washer leaves lint & white smears on the cleaned cloth
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
WHERE IS LINT FILTER ON ELECTROLUX FRONT LOADER 7KG
Hello - I will be happy to assist you. However, in order to provide the information you are requesting, may I please have your model number. Typically, the lint filter is located on the lower front as you open the door.
Jan 02, 2013 | Washing Machines
Where is the lint filter on Whirlpool Washer Model LSQ7030LQ0?
There is no lint filter on your unit. What kind of problem are you having?
Apr 25, 2012 | Whirlpool Washing Machines
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Washing machine not rensing well
there is a magic clean filter on bottom of basket. it has been removed from newer models because it builtup **** and never cleaned itself. need to remove agitator and basket to clean tub and remove plastic filter from bottom of basket. special tool required for basket
Mar 14, 2009 | Washing Machines
Whirlpool Washing Machine Lint
Most washers no longer have a lint filter. Post your model number and I'll try to find out if your model has one.
Mar 09, 2009 | Washing Machines
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
