Question about Lexmark Interpret S405 Wireless All-in-One InkJet Printer
Blue wont print on documents... its always purple have realigned cartridges.... did a test page... the blue came out with lines across it... yet it is a brand new printer with a brand new cartridge what is going on?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 544 Answers
I will do a Clean Printhead cycle.
This will clean the printhead.
Clogged printhead nozzle will cause lines.
Posted on Mar 13, 2011
Why blue lines when document printing?
You need to do a head clean you should be able to find this in maintenance section of the printer program.
They get a little dry spots or dirt on the cartridge.
This is a ink eater so uses a heap of ink could take 2-3 head cleans to clean it.
Regards Craig
Feb 11, 2018 | Office Equipment & Supplies
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Whenever i print a document, y get white lines at best, sometimes i get nothing, but in the test page i always get an awsome quality. whats going on?
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 25, 2011 | Office Equipment & Supplies
Lexmark x1270 wont print color even though the cartridge is full.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
My printer is running a white streak through the center of pages
1. Turn the power to the printer "off."
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
May 05, 2009 | Lexmark Z715 InkJet Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp 5550dn ( I am getting a 49.2fcc and 49.4b1a error
Upgrade firmware on the printer as a first step, 49 errors are often an issue with firmware
Nov 12, 2008 | HP LaserJet 5550DN Printer
Printer Prints Blue Test Page but not in black
Your color cartridge is probably empty as well. you can go to>control panel>printers and faxes> your printer >right click on preferences then click on services. Do all of the maintenance possible on your cartridges and see if that helps. Are your cartridges HP cartridges or generic refills?
Apr 22, 2008 | HP DeskJet 810c InkJet Printer
Lexmark Interpret S405 Wireless All-in-One InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
