Question about Ovens
My self cleaning oven is locked i had an F2 error message displayed on it and now cannot open the oven.
  • Ovens Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
This is a fairly common issue that happnes with these ovens during this cycle
These ovens have a internal reset device that needs to be reset and here is how to do it
first you need to unplug the oven then leave it for 1 hour and do not touch it then after the hour is over and not before plug in the oven again and then you may hear a audiable beep or click within 5 minutes of plugging it back in that is ok just press the cancel button when you hear this now try once again to unlock the oven it should unlock now ok?
But if not then you will need to remove the lower drawer then reach up inside the oven where the door latch is and there is a release tab that you need to pull on to release the door
+++ NOTE+++ iF YOU HAD TO USE THE TAB TO RELEASE THE DOOR THEN YOU HAVE A FAILURE OF THE CONTROLE PANEL WHICH IS A BAD THING THIS NORMALLY OCCURS FROM THE EXCESSIVE HEAT FROM THE CLEANING CYCLE IT ENDS UP SHORTING OUT THE CONTROLE PANEL WHICH IS A BAD THING OK
Hope all of this helps
Best regards Mike
Posted on Mar 13, 2011
Self-clean-mode not working, I get the "door" error message
are you sure it is an auto lock door and not a manual locking type .
Oct 22, 2015 | GE Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Jan 25, 2009 | GE JKP15 Electric Single Oven
E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
E2/F2 Error
The Model number is a RBD306PDB6 i found that one as far as the code
F2=
E2 Keypad not connected
1. Check keypad connector for firm connection.
E3 Key held down too 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
long, or key is shorted
Feb 17, 2008 | Ovens
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
F2 error message
Hvace, F2 is a shorted temperature sensor. Probably took it out with the self clean...Catriver..post back.
Aug 31, 2006 | Whirlpool GBS307PD Electric Single Oven
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
