Question about MSI Wind U100-016US Laptop
Hi. I recently had my keyboard disabled because of sticky keys. I want to turn it back on, so that I can try & enable the wifi. I just looked in the bios, but cannot find the setting to re enable the keyboard. How can I do this? Thank you.
    Genius:
  • 1,189 Answers
Hi davelarz, these instructions will help you. *Note: "Everything that you do for the Keyboard!" "Can be applied with the same instruction to the Mouse." First, click on the "Start" button. Hi.
I recently had my keyboard disabled because - paul7of9_163.jpg In the ["Start Search Window], type: keyboard. Now, Click on the "Keyboard" shortcut. It should appear at the 'top' of the list. paul7of9_164.jpg The "Keyboard Properties" window will open. You can (Test) to see exactly how your keyboard is responding. Select the [Hardware] button. Next, click on the {ProHi. I recently had my keyboard disabled because - paul7of9_165.jpgton. paul7oHi.
I recently had my keyboard disabled because - paul7of9_166.jpgs= Choose the (Change Settings) button. paul7of9_166.jpg Next, click on the "Driver" button!." "You will be in the 'area' where the "Keyboard" can be [Enabled / Disabled]. Next, "Enabled the Keyboard." Click on the (OK) button. "This should do it for you!" !Important: If you are still having the same problem? Check: the Keyboard {Status}. "Update the Drivers" Click on the "Properties" button. Select the {Update Driver} button. Next, click on the "Apply and OK buttons!" !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Posted on Mar 13, 2011
  • paul7of9
    paul7of9 Mar 18, 2011
    This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
I seem to have locked my keyboard and can only use the one on screen, since this computer is touch screen
By the sounds of it, you have enabled your computers Sticky Keys. To disable the Sticky Keys, go to Control Panel -> Accessibility Option and disable everything.
Note: Sticky Keys are enabled by pressing the shift key five consecutive times.
Feb 27, 2015 | Dell Computers & Internet
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
Sticky keys on my laptop
Navigate to:
Control Panel\Ease of Access\Ease of Access Center\Make the keyboard easier to use
To Disable your sticky keys issue.
If FN+F11/F12 is not working to enable your wifi, try:
Hit windows button or open start menu, search for "device manager"
Open that, find your wireless card under: network adapters
Double-click it, and look through the settings for enable/disable, or radio on/off and change the settings.
Jun 14, 2013 | Computers & Internet
HP ProBook 1. Everytime i try to type in a box the screen closes to the desktop 2 my font size always changes; i have to continually change it back to 100, how do i get it to stay.
Seems the on board keyboard had problems ( sticky ) Have you try using Usb keyboard? I guess the 'Sticky key' is Ctrl or Alt key. you can try pressing Shift key 5 times repetedly ( to disable sticky key )
Try remap keyboard > ( to disable sticky key with application )
akee.4shared.com
Aug 15, 2011 | Computers & Internet
Sticky keys how do i fix it?
Hi Dgr Welcome to fix ya !
The sticky keys are part of Windows Ease of Access Center Accessibility program.
1. The easiest way to enable/disable the sticky keys is to press the "Shift " key five times. This will turn on/turn off the program.
2. The second way is to press the Windows logo key + U at the same time. This will open the Ease of Access Center. Then select the link that reads" Make the keyboard easier to use."
3. Under the section that reads, "Make it easier to type" you have the option to enable the Sticky Keys or a link to Set Up Sticky Keys. Select whether you want to set up the Sticky Keys or just enable them if you have previously set them up. If setting them up for the first time, remember to click "Apply" after making your selections.
Hope this helps. If you need further assistance, just leave a comment at the end of this solution and I'll be glad to help. Thanks for using Fix Ya.
Jul 10, 2011 | Computers & Internet
DEL Inspiron 1525 Held down some keys too long, got a warning (filterkeys?)... keyboard is now locked and will not type. How do I unlock it, please help.
Hi Stan,
Your issue is just that you enabled the sticky keys of your portable system. all you have to do is to disable it again. Just go to control panel then go to accessibility options. Choose Ease of Access. You will find an option to change how your keyboard works, click on that. You will find check boxes. Uncheck the sticky keys, filter keys.
Jul 07, 2011 | Dell Inspiron 1525 Notebook
How do you turn on the WiFi feature?
Pressing the keys Fn + F1 at the same time will enable or disable the built in wifi.
Mar 02, 2011 | Coby PC Netbook 1ea
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Can't type anything without weird things happening the \'p\' prints,
hi, check that Sticky-keys arent turned on.
to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
Sep 10, 2009 | Acer NSK8458AN Keyboard
MSI Wind U100-016US Laptop Logo
391 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
