Question about Systemax AOL Optimized PC (100607) PC Desktop
When i power the pc, the booting process stops at this message: "floppy image loaded". I can not do anything since the curser is unresposive. Jack
    Problem Solver:
  • 7 Answers
If you have any flash drives, external drives hooked up, disconnect them. Also, if you have a 3.5" floppy drive, get the disk out of there.
When the computer is loading, look for an option (usually at the bottom of the screen,) that says enter BIOS. Usually is F1 or the Delete key.
*Disclaimer* If you do not know what you are doing the the BIOS, do not mess around with it.
Scroll through the options, using the keyboard, and look for something similar to 'Boot Device Priority.'
Now, unless you still do have a 3.5" floppy drive connected, you will want your first boot device priority to be the C: drive (Default system partition with Windows.)
It just seems like some drive on your computer is trying to boot something, maybe emulating a floppy drive to do so.
Posted on Mar 13, 2011
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
DC7600 Wont boot from win 2003 CD
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
Hope this helps
Dec 09, 2012 | HP DC7100 PC Desktop
After reading the BIOS software, my Gateway CX200X gives the message: MBR error. what is this?
MBR stands for Master Boot Record. It is an essential piece of information written on the Hard Drive that allows the program to load. If the MBR is corrupted the computer boot process cannot proceed.
You have to repair it.
On old systems with a floppy drive you would get a Win98 boot disk on a floppy, boot the system using the A:drive (floppy) then use a DOS command to refresh the Master Boot Record.
If your system is using Windows XP tablet PC edition you might be able to use the installation disk to boot to the recovery console and use the command FIXBOOT or FIXMBR. You can also reinstall the Operating System.
I hope this answer gave you some starting point to investigate further. There are on the web some software vendors who sell system recuperation CDs. Some may be free other you have to buy.
Jun 10, 2012 | Gateway CX200X Tablet PC
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
On my pc monitor appears " Floppy diskette seek failure"
To remove the message just go to bios, press f2 when you turn on your computer, press enter in boot menu, set first boot in hdd and second boot in cdroom (using + - key)and disable boot from floppy by pressing the space bar
Go to advance and if there is any setting about swap or seek from floppy make it disable
Hope it helps
May 28, 2011 | Dell OptiPlex GX280 PC Desktop
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
Hi I have a Hitachi Travelstar Model: HTS548060M9AT00 DATED JAN 05 that was in my Windows 2000 Dell Laptop. When I try to start up. It starts clicking and then the computer says "boot...
Go to this site
and download either the bootable diskette image or the bootable CD image to create a bootable floppy or CD. Will needed a working computer to do this on and a working floppy or CD drive on the faulty computer. Once the troubleshooting floppy or CD is made, load it into your faulty computer and reboot that computer. If the bios on the fault computer is set to allow booting first from floppy or CD, the troubleshooting routine will be loaded by the computer as it boots up.
If you are interested in saving any data, do not format your faulty drive and do not write ' 0 ' s to the drive in the troubleshooting routine.
These troubleshooting routines will only work for Hatachi drives of your model series, waste of time to try to use them on other manufacturers' drives.
It sounds like your drive has met it's maker, the clicking you mention is normally a ' dead ' giveaway, but it may be possible that the Hatachi troubleshooting routine can help in some fashion.
Best of luck, you will probably need it.
Aug 25, 2008 | Hitachi Computers & Internet
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Systemax AOL Optimized PC (100607) PC Desktop Logo
    48 people viewed this question
    Top Systemax Computers & Internet Experts
    Gareth Cockram
    Gareth Cockram
    Abhinandan  Patil
    Abhinandan Patil
    Mike
    Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
