Question about Cell Phones
My touch screen on my HTC Pure is unresponsive. It has always worked perfectly fine till 10 minutes ago. I soft reset it and it dent fix it,I would try a hard reset but you need to access that menu through the screen. My hard buttons work like the volume, the windows key, back button and end and answer call buttons. please help me fix it before I huck it out the window. Thank you, Kale Nostrand
  • 139 Answers
SOURCE: htc touch screen not working.
Hi reset your cell phone to factory setting else you have an option in HTC to reset your display settings. Yasha you need to go to the settings and then to the display option to make a new touch screen settings
Posted on Jan 09, 2009
SOURCE: stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Posted on Mar 17, 2009
  • 6 Answers
SOURCE: Blackberry Storm: My Menu button and end button do not work
This problem happened to me and I just figured out the answer. If you recently installed a new application or a new theme then it will probably mess with your button configurations. Remove the theme/application you installed just before the problem started happening. Once you removed the theme/application convert back to the default theme and your buttons should work again.
Posted on Jul 01, 2009
SOURCE: Unresponsive touch Lg Dare Touch screen
sometimes you just need to take the battery out and put it back in. If you've already done that then you may need to take it to Verizon and get it updated.
Posted on Jul 09, 2009
  • 157 Answers
SOURCE: Samsung i9oo Omnia wont turn back on
There is a JTag Tool Exist for such problems and it is the only way !
You can find at : www.omnia-repair.com
Or you can also send them to repair your phone ..
Best Regards
Posted on Aug 01, 2009
My samsung sch-r710 touch screen is unresponsive. Will a hard reset fix the problem? How do I perform a hard reset?
try to calibrate the touch sensitivity setting before you reset it this always work in any case.nno need to to do a hard reset
Aug 14, 2012 | Samsung Lands Phones
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
Hi, im using my htc touch bviva from past a year i dint had any problem till date but from past 2 days my touchflo stopped working my cell phona is working fine only problem with the user...
Turn of your phone and remove the battery for 10 minutes. The reinsert the battery and deploy the HARD RESET ( Check HTC Viva Manual how to do hard reset). Also you may try to clear storage in the settings. BY doing this your device will reset to orginal factory settings.... BE SURE TO BACK UP YOUR DEVICE before starting this... you can use SPRITE BACK UP also available on the HTC website.. download both device and PC software ... take back on PC for easy restore.
Good Luck..
Aug 22, 2010 | HTC Touch Viva Cell Phone
Hi my htc touch viva is seized up. what can I do if nothing moves on the screen?
try restarting it.... if still frozen ... open the back cover and remove the battery... replace it after 10 minutes.... start the phone.. if all is ok then fine else you can soft reset the phone ...if still not working then hard reset the phone...before you try anything back up your phone....check the manual to know how.
Aug 08, 2010 | HTC Touch Viva Cell Phone
How to reset the phone HTC Touch
Press and hold Call/Cut buttons(green/red) and soft-reset with the stylus. Keep holding the Call/Cut buttons till you get a message on screen saying "This will erase all your personal data" message on screen. Then press 'action' (enter button) to hard reset.
And to enter the bootloader: (Required sometimes while flashing ROMs)
Hold down the camera button and reset device with the stylus. Keep holding the camera button until you see 'tricolor' bootloader screen.
May 14, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch Pro 2 - screen frozen - how to fix prob??
I have a similar problem with my HTC Touch Pro. A hard reset didn't work either!
Let us know if you get an answer!
Sep 22, 2009 | Computers & Internet
Unresponsive htc tytyn touch screen
i had the same problem, it turned out to be dust caught just under the plastic at the edge of the screen, a finger nail got it out or you could be fery careful and use a sharp flat knife. hope that helps,
Jul 28, 2008 | HTC TyTN Smartphone
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
Htc touch charging port stop working
It may be caused by dirt ingress in the port, check for dust and clean out with a soft fine paintbrush (like an artist brush) soaked in pure alchohol, or vodka! Short of that solution, purchase a charger of ebay and place battery in the rear to charge.-
http://cgi.ebay.co.uk/DESKTOP-CRADLE-CHARGER-for-HTC-TOUCH_W0QQitemZ130204421069QQcmdZViewItem?hash=item130204421069&_trksid=p3286.c81.m63.l1177#ebayphotohosting
Kind Regards, ACD
Mar 03, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
