Question about Intel Create And Share Camera Pack Webcam
I need the installation disk for my intel cs630 camera that is compatible with windows 7.... does it exist?
SOURCE: DRIVERS FOR INTEL CS630 FOR VISTA
need vista drivers for intel cs630
Posted on Nov 01, 2008
SOURCE: i want of install free software if intel cs630 canera
I WANT FREE DOWNLOAD THE INTEL CS630 WEBCAM
Posted on Feb 16, 2009
  • 7 Answers
SOURCE: how to use Intel PC Camera CS630
Cycle with mode button -- HD is hi resolution, video icon takes videos. Push large oval button to take pictures or start video recording. Lens can be set to infinite focus at mountain icon or focused. Don't forget the on/off switch (circle with 1 in it)
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: intel cs630 camera
Cycle with mode button -- HD is hi resolution, video icon takes videos. Push large oval button to take pictures or start video recording. Lens can be set to infinite focus at mountain icon or focused as needed for close shots. Don't forget the on/off switch (circle with 1 in it)
Delete is accomplished by holding mode and shutter button 5 seconds.
Use Picasa or like software to manage.
Drivers CS630 XP.exe are on Intel site as well as simple downloader.
SOURCE: intel webcam cs630 software
i want the drivers of intel pc pocket camera cs630
Posted on Jan 02, 2010
I have intel pc camera cs630. i want to install for driver and my operating system vista
Hi, I found drivers for your Intel CS630 Webcam here: http://download.cnet.com/CS630-XP-EXE/3000-18493_4-104406.html or Click Here. The drivers say they are Windows XP drivers, but they have been Windows Vista certified as compatible.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | Intel CS630 Webcam
How can i instal pc camera cs630 driver for windows seven operating system?
actually this camera only supports win 200 and xp , not compatible for win 7..
if you want drivers for win 7 you have to contact intel..
Dec 30, 2010 | Intel Computers & Internet
Intel CS630 no longer works
1st You download Webcam Driver. Free Intel webcam Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 05, 2010 | Intel CS630 Webcam
I need driver cs630 webcam
you can download driver from
http://www.opendrivers.com/downloaddriverurls.php
or
http://www.nodevice.com/driver/Pocket_PC_Camera/get30405.html
iTechGuru
www.iTechGuru.in
Mar 29, 2010 | Intel CS630 Webcam
Need driver for Windows 7 Disk I have not compatible.
1. You will need administrator rights to your PC. If you do not have these rights, please consult with your network administrator or your parents (assuming that an adolescent may read this post)
2. Go online and search for the file CS630-XP.exe and then download it (if you don't have the install the disk. If you have the disk, proceed to step 3 but browse your disk for the setup.exe file and follow the program compatibility from there). I would share this file but copyright to Intel and Microsoft's Terms for posting on Windows Live forbid it, so you will have to search out the file. Sorry!
3. Once the file is downloaded, Extract the files then view the folder. Open up Control Panel, Programs, and go through the program compatibility steps to set the program to run as if your OS was still Windows XP SP3. Then, go back to where you downloaded the install file then right mouse click on the file and click "Run As Administrator"
4. Once the program completes, connect your Camera by plugging in the USB Cable into your PC.
5. If the "AutoPlay" Options do not appear, you will need a third-party program to retrieve your photos from your camera. I recommend Google's Picasa to handle this task. Go to Google and download Picasa,
To retrieve Pictures from Camera using Picasa:
1. Click Import
2. Click on the drop down menu till you see your device (e,g, Intel(r) PC Camera CS630 Image Storage)
3. You will then see all the photos stored on the camera
4. Select the ones you want then the rest is easy. Select where to import them to and then import!
Clearing Camera Memory
From time to time you may need to clear your camera's memory to make room for new photos. The only way to do this is through your OS (assuming you may not be running Windows). Go to Control Panel and in the search box on the top right type in "camera". Click the first button which says "View scanners and cameras". You should then see your device listed. Click on it then click Properties. Click the Camera Memory Tab then click Clear Camera Memory. Once cleared, click OK.
I sincerely hope this helps you!
Jan 06, 2010 | Intel Create And Share Camera Pack Webcam
Jul 16, 2008 | Intel CS630 Webcam
Installation
you did not mentioned OS if it is Vista then no way as I have contacted Intel Corporation also as Intel Camera CS630 designed so early and not compatible for Vista. For other OS go to folowing intel site.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=425&OSFullName=Windows*+2000&lang=eng&strOSs=19&submit=Go%21
Thanks, Aamir Nazir ****, Jpn
Jul 10, 2008 | Intel CS630 Webcam
I cannot install my Web camera on my window 98 PC with the CDprovided with PC Camera CS630.
Wow, you have the CD? Please upload the drivers from the CD. Please use a different computer than the one you are having difficulty with because the CD drive may be causing the problem.
Dec 20, 2007 | Intel CS630 Webcam
Cs630 digital webcam
Here is the link to download Intel CS630 driver http://download.cnet.com/CS630-XP-EXE/3000-18493_4-104406.html
Nov 14, 2007 | Intel CS630 Webcam
Intel Create And Share Camera Pack Webcam Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
