Question about NZXT Guardian 921 RB 921RB001RD Black SECC steel chassis ATX Mid Tower Computer Case
I wanna know were the HDD CPU SYS what are they for and were do they go
  • Menow 173
    Menow 173 Dec 25, 2017
    are you talking about the wires inside of the tube if so they are used to calculate the temperature and that information is sent to the front panel so keep the labels on them and put each wire close to the item
Ewf
Posted on Aug 17, 2012
Toshiba e 255 is error code F110 how to c?ear
[F110] Communication error between system CPU and scanner CPU
(1) Check if the harness connecting the SYS board and SLG board is disconnected or open circuited.
(2) Check the version of the system ROM on the SYS board.
(3) Check the version of the scanner ROM version on the SLG board.
(4) Replace the SYS board.
(5) Replace the SLG board.
May 14, 2017 | Toshiba Office Equipment & Supplies
"I tried to install another internal HDD + another 256 RAM (both of them are used) to my computer, operating XP with an ASUS P5P800S motherboard. When I ran the system, the new device was found by the sys....
The hard drive would not show up until you initialize it in the control panel. With everything off the motherboard you should get some post beep. Put the ram back and try again, the next thing to install is the video to see if there is any indication of function. Keep adding things back. If there is no post beep with just the motherboard then you need to test the PSU and if it is OK then CPU or motherboard is bad.
Sep 26, 2014 | ASUS P5p800s Motherboard Intel 848p Lga...
High CPU usage from interrupts and ACPI.sys
go to bios see if the cpu cap is off or on also go to system in computer and adjust all index options can also try cpu usage controls in control panel
Feb 28, 2013 | Computers & Internet
I'm building an new system and get a BSOD (Attempt to reset the display driver and recover from timeout failed.)with STOP 116(hex) and a warning about atikmpag.sys. When I first load the OS (Win 7 Pro,...
make sure all the power connectors are connected to the card ,then run the ati driver cleaner,or any driver cleaner of your choice will work,then install the catalyst 11.2 and see if that works,worked for mine.
Apr 27, 2011 | Computers & Internet
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Unable to boot into windows
what are the things that you added recently, hardware(additional hdd, memory, video card) or software (antivirus, office, etc games.) try running a hard drive diagnostics, usually computer manufacturer install a hdd diagnostics on their BIOS that you can run. hit me back on the results.
Apr 28, 2009 | Dell Inspiron mini 9 - Black , IntelĀ® Atom...
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
ToshibaStudio 350 , showing code F105
F105 indicates HDD problem.
U need to check followings:
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are broken.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the
check result is failed, replace the HDD.
Jan 25, 2009 | Toshiba e-Studio 350 Copier
T41p boot issue
This sounds like a memory problem. Remove the memory, then try each chip one at a time in each slot. Try this and let me know.
Aug 24, 2008 | IBM ThinkPad T40 2373 Notebook
NZXT Guardian 921 RB 921RB001RD Black SECC steel chassis ATX Mid Tower Computer Case Logo
174 people viewed this question
Top NZXT Computers & Internet Experts
David Payne
David Payne
Are you a NZXT Computer and Internet Expert? Answer questions, earn points and help others
