Question about Samsung PS42A410 42 in. HD-Ready Plasma TV
Our PS42A410 TV work for 5 minutes and the "Weak or No Signal" is displayed. It is not our ariel so it has to be the TV, can you assist at all?
  • calliewalter Mar 13, 2011
    Thanks tunde007 but it's not the Hdmi cable, we took it out and it still doesn't work. The tv aerial cord is working too so not sure if it's a setting on the tv or if we need to replace the whole tv?
    Thanks tunde007 but it's not the Hdmi cable cos we took it out and it still doesn't work, it's also not the aerial cos we have replaced that too. Could it be a setting on the tv or that it is just stuffed and we need to replace the whole thing?
    New Friend:
Did you ever get a fix for this?
Posted on Dec 01, 2012
  • 2,382 Answers
Hi, you have a faulty HDMI cable which is causing the "weak or No Signal" to display.. Replace the HDMI cable...
Posted on Mar 13, 2011
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
My mother in law has a 3 mth old panasonic tv with built in freeview that keeps going off saying no signal check ariel. ariel has been checked, any ideas anyone please
access the signal strength in the menus and see how it looks. Too strong a signal can also produce the same problems as a weak signal. If it shows full strength but poor quality then it may be too strong a signal.
Mar 23, 2013 | Televison & Video
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Tip
How to change a broken electric ariel on a saab
my electric Ariel stopped working and I was quoted £87 to replace it I bought a replacement on ebay for £13 its a simple fix just undo the Ariel nut on top of the car rear wing get someone to sit in car and push radio button old ariel starts to come out simple assist it until it has completely come away from car put new lead into hole then get person in car to switch of radio and feel the ariel start to be pulled back into place be carful to keep it straight as it enters then replace locking nut total time less than 5 mins cost £13 plus one person to assist easy fix
on May 07, 2015 | Saab 9 Cars & Trucks
Ps42a410 everything displays but with the picture no colour
Please try to reset it in service menu. If it doesn't help check scalar and components around it.
Feb 04, 2010 | Samsung PS42A410 42 in. HD-Ready Plasma TV
Tried to rescan after digital change over and it wont keep the signal, i have digital tv and digital ariel
Sounds like you have weak signal in your area, unlike analog TV , if the signal strength is below a certain level it will completely reject channals, try a standard antenna with two rabbit ears and a loop. If your TV has a signal strength meter you can watch that while adjusting the antenna.
Dec 15, 2009 | Televison & Video
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Samsung PS42A410 42 in. HD-Ready Plasma TV Logo
157 people viewed this question
Jerry Greenberg
Jerry Greenberg
