My Canon mp280 printer is says in error 5200 on my computer screen. on the printer it is showing p08. can you tell me whats wrong and how to fix it?
SOURCE: Canon mp 270
The following tutorial on youtube.com helped me to fix this problem:
http://www.youtube.com/watch?v=RoiBaXVhS7g&feature=related
Posted on Jun 15, 2011
  • 29 Answers
SOURCE: error 5200 or P08 on
The error indicates the following : Head overheating error.
Yes it is most likely the print head itself or at worst the logic board.
Replace head/logic board is the only answer.
Posted on Jul 20, 2011
Joed911
  • 4338 Answers
SOURCE: hi, my canon MP250 is
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
Posted on Jul 21, 2011
  • 2386 Answers
SOURCE: What is the meaning of the error code p08 error
Hello
This error is wasted ink full reset the printer press reset button and hold then press on relase and press twice reset button is now in maintenance mode to reset wasted pad ink press 4 times the reset button then turn the printer button on/off
Hope it helps, good luck
Posted on Dec 22, 2010
  • 89 Answers
SOURCE: my Canon MP270 printer shows
P08 (Print head temperature rise error) : 6. P08 (Print head temperature rise error): thermalprint head temperature exceeds a threshold.
Replace the new cartridge print head and / or change a new logic board.
Posted on Jan 12, 2011
Canon pixma printer mp280 !!error code p08 tried suggested answers, take off electricity, when on again hold on button ect. need help ! thanks chris
The standard info on this code is:
5200/P08 - Orange and green light blinking 8 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
That said, it is often a generic response meaning the machine has a problem but doesn't know what.
In the first instance check inside the machine at both ends of the carriage bar - look for a soggy black mass of crumpled up paper and remove if found. If there is nothing to find, it is possible that there is a printhead fault although typically this gives a P05 error. Try swapping out the cartridges with an old used one. Change one at a time to identify if one or both are faulty. If that fails, it is probably worth replacing the machine as it is relatively aged and new equivalent versions are really cheap.
Nov 02, 2017 | Canon Office Equipment & Supplies
Will not print. What does error 5200 indicate?
See: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5200
Resolution:
  6. Close the cover.
Jan 18, 2016 | Canon PIXMA MX340 Wireless Office...
Instead of printing error number 5200
Error 5200 and Error P08 are same.. Remove your catridge for few minutes and replace ...
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error 5200 or P08 on canon pixma mp495
Jul 11, 2011 | Canon PIXMA MP495 InkJet Printer
My Canon MP270 printer shows the following error 5200 P08
Jan 12, 2011 | Office Equipment & Supplies
What is the meaning of the error code p08 error 5200 showing in the canon pixma 250 inkjet all in one?
Hello
Dec 22, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have canon mp 258 with error e27 how would i resolve it?
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jul 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My canon mp258 show error code p08 ,,what to do
printer canon mp258 eror code 5200
or p08 warning in printer
Apr 12, 2010 | Office Equipment & Supplies
5,824 people viewed this question
k24674
jasbo
jasbo
