Question about Dewalt Vacuums
My DC500 works fine running on battery power, but the motor hesitates for a moment or two when the unit is switched on with ac power. After this it works fine. What might be wrong?
  • Dewalt Master
  • 1,886 Answers
May be the carbon brushes are short or motor connectors have become bad connection by moisture and dirt by use temporay a wrong filter sometimes its a very light and simple motor johnson motor with hammer brushes
DeWALT DC500 Type 1 Vacuum Parts
Posted on Dec 02, 2015
2 Suggested Answers
  • 67 Answers
SOURCE: My Dewalt dc500 only works on AC power (plugged in
Check battery contactor on the vacuum and on the battery. It is a common problem on this vacuum. Check for bent pins and corrosion.
Posted on Sep 16, 2010
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
Why vacuum works for a few seconds only
Check the batteries with a voltmeter. Inspect the wiring for loose connecions or broken solder joints. Check the switch with a continuity tester.
My Dewalt dc500 only works on AC power (plugged in to wall socket). When you put in the battery it doesn't work. Can anyone help?
Jul 13, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
DeWalt DC500 wet/dry vacuum
I had the same problem and traced it down to the on/off switch. I sprayed some electical contact cleaner down inside the switch and now it works normal. Hope this helps.
Oct 23, 2008 | Dewalt DC500 Canister Wet/Dry Vacuum
Won't turn on
If there was a smell like something plastic burning it may be that something just actually burned. It does not have to smoke like a chimney (sometimes it does though - depends what is burning)... If there were no strange noises and it did not seem to run any different than usually - most likely the motor is still fine. I would inspect the cord really carefully but to do any more than that you would have to open the unit and inspect everything else.
If you chose to do so – open the Rainbow and hook up the motor directly to a power supply (hold on to the unit as it will move while starting) – if it runs then problem is in wiring. Test the cord with a tester or bulb, then the switch (or 2 switches if this is e-series Rainbow). Make sure all wires are intact. There is not much to test so you will get it done and find the problem quick.
This is messing with electricity and subjecting you fingers to potential hazard by exposing working motor so do it at your own risk and be very careful and if anything goes wrong do not blame me :-)
Aug 31, 2008 | Rainbow E series Canister Wet/Dry Vacuum
DeWalt DC500 Shop vac
the problem on your vacuum is the dc - dc converter.u cna replace them but to follow the same connection.
Oct 02, 2007 | Dewalt DC500 Canister Wet/Dry Vacuum
Vacuums Logo
77 people viewed this question
Top Dewalt Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pcm2048
Are you a Dewalt Vacuum Expert? Answer questions, earn points and help others
