Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan 3100 will not take a charge
  • jessica_porr Aug 31, 2008
    carge it but it wont go on
When the unit is turn on, the unit ask to insert sd card to install map
Posted on Aug 30, 2008
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Won't charge
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can get it repaired,
here
Or buy the port here
If you need further help, just let me know.
Dec 31, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan gps is blank what can I do?
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 3100 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging and i can tell you where ot get it repaired or by the power port if your able to solder it on the main board yourself.
you can get help to repaired it, here
Nov 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
LCD replacement for a Magellan 3100
these 3100 and magellan 2000,2200t,2500,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if you magellan gps is not charging or will not power up, its most likey the dc power port...i sell these ports and will repair them for anyone thats not able to do it them selves ....wmetz@comcast.net
ebay id imbmetz1
Jun 20, 2009 | Magellan RoadMate 2200T GPS Receiver
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan GPS 3100 is dead. I plog in from car charger for few minutes and I also push the reset button, does not work at all. Any one have any solution.
most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.net
Feb 12, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
41 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
