Lysol with bleach was sprayed on my tv screen, now a white powder is on the screen and it keeps coming back within a day after dusting it off. The clean air machine in the same room also has the white powder appearing on it and has to be cleaned every 2 days. What is this substance and how can I get rid of it?
the dr
  • 447 Answers
SOURCE: DWU8260aax dishwasher, Maytag
What kind of soap do you use??? How much??
Posted on Nov 23, 2007
SOURCE: LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Posted on Dec 28, 2007
SOURCE: westington LTV-27w7 HD black screen
If the power light stays on green, I would look tward a backlight issue. If you can see any image at all then the backlight controler or the backlights are bad. If there is nothing then if could be a power supply overheating or an inverter failure. More than likely as the unit heats up a failed solder connection is loosing contact causing the screen to go black.
Posted on Feb 10, 2008
barkencoa
  • 3463 Answers
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Posted on Dec 28, 2008
HW_Dude
  • 87 Answers
SOURCE: Internal HDD hard error
By your description it is very likely your hard drive finally failed. You probably looking at total data loss unless you have made recently an backup of it. You will have to get a new HD and then you can install your OS and software.
Another more remote possibility is that when you opened some covers, you accidentally disturbed the HD connection causing this problem.
Just for clarification, was there a lot of dust inside ?
Hope this helps.
Posted on Jan 12, 2009
Can I use Sprayway 360* multi surface cleaner on carpet
I highly recommend that you don't. Most multi-surface sprays are not made for carpets, but hard surface materials. They may contain disinfectants that could actually bleach or harm the carpet. I recommend using only carpet cleaning spray or a water-Lysol combination.
Elisa Jed ' http://www.floorcleantoowoomba.com.au/services
Mar 14, 2014 | sprayway"" 360 degree all- around...
Our baby monitor is constantly losing it's signal. We have reset the camera and monitor several times. When we scan "search for camera", it's good for a day but once it's shut off and turned on again, it...
We just purchased a soothing comfort playard and changer from a garage sale. It looks very clean and nice. However, you can NOT remove the fabric from the construction. Construction is put together with rivets that are not removable. Here is the method we will use to clean it. We will take it outside in the yard and hose it with clean water. While it is still wet, we will sprinkle plenty baking powder on the fabric and let it soak for a few hours in the sun. Then, we will purchase one of those general purpose liquid spray cleaners (such as Lysol). My wife insists on using a scrub brush and some laundry detergent (protect your hands), which is OK. If you mix in some bleach it would kill all germs as well. After the application of cleaners, and scrubbing, leave in the sun for one more hour. Then, use the garden hose to completely rinse off all the chemicals. The baking powder will get rid of all smells, and the bleach or Lysol will kill all germs. Do not worry about a few stains; they will be "sanitized" stains. :-)
Sep 27, 2013 | Summer Infant Baby Care
I have a Natures Purest Hug Me Soothing Comfort Bassinet by Summer Infant. It was given to me with no instructions and I want to wash the bassinet fabric that goes over the frame and the bottom storage...
We just purchased one from a garage sale. It looks very clean and nice. However, you can NOT remove the fabric from the construction. Construction is put together with rivets that are not removable. Here is the method we will use to clean it. We will take it outside in the yard and hose it with clean water. While it is still wet, we will sprinkle plenty baking powder on the fabric and let it soak for a few hours in the sun. Then, we will purchase one of those general purpose liquid spray cleaners (such as Lysol). My wife insists on using a scrub brush and some laundry detergent (protect your hands), which is OK. If you mix in some bleach it would kill all germs as well. After the application of cleaners, and scrubbing, leave in the sun for one more hour. Then, use the garden hose to completely rinse off all the chemicals. The baking powder will get rid of all smells, and the bleach or Lysol will kill all germs. Do not worry about a few stains; they will be "sanitized" stains. :-)
Aug 21, 2013 | Summer Infant Nature Purest Soothing...
Been dealing with a smelly washer- tried the usual, bleach, vinegar, CLR.....it doesn't seem to have a lint trap.....is there one? where might it be?? Its old but works great other than this.....
Have you tried doing an empty 90 degree wash with white powder?
It does have to be white powder rather than colour powder or any kind of liquid, becauses only white powder has bleaching agents.
Add it helps if you leave the machine empty or clothes, towels etc.
Washing machine smells are usually caused by mildew, and a 90 degree wash with bleaching agents ought to help. If you do this about once a month it should keep the machine clear of mildew.
Jul 25, 2011 | Washing Machines
I suddenly have the smell of urine in my dryer. Nothing was washed with any urine residue. I always double rinse each load and often use a little bleach with my "white" laundry. A couple of...
The only thing that I can think of that could produce a urine/ammonia smell is a shorted capacitor that is leaking. But normally when that happens the dryer motor will not start.
Jun 17, 2011 | Dryers
My new lg optimus one p500 is having a dust inside the screen.. within 15 days of purchasing the cell phone the dust is getting increase day by day.....after cleaning the dust from authorised service...
my new lg optimus one p500 is having a dust inside the screen..
within 15 days of purchasing the cell phone the dust is getting increase day by day.....after cleaning the dust from authorised service center its coming again on the screen.........ohhh ghoosh.. im fed up wth this new lg phone (lg optimus android 2.2 froyo.based) lgp500.
Feb 09, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
What are the Fragrance Abbreviations?
EDT: Eau de Toilette
EDP: Eau de Parfum
Col: Cologne
C/S: Cologne Spray
A/S: After-Shave
Spy: Spray
Sp: Spray
B/L: Body Lotion
Bdy: Body
B/P: Body Powder
D/P: Dusting Powder
Dust: Dusting
Pwdr: Powder
B/C: Body Cream
B/G: Bath Gel
Conc: Concentrate
P/S: Purse Spray
Nov 23, 2010 | Health & Beauty
Ive just brought a re-conditioned bosch classixx washing machine,
boil wash the machine with old towels and powder, 90 degree wash will bring out the bleach in the powder and the old towels will throw the bleach around the tub removing the bacteria that has grown in the tub, the bacteria comes from the washing powder to eat the dirt in clothes and sometimes gets left in the tub and pipes (most people only wash at 40 degrees the bleach wont come out the powder until at least 60 degrees hence the build up and smell). you may have to do this twice to get it smelling good, remove the drawer also and clean off any bacteria with a cloth and spray bleach.
Jul 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
How do you get the water overflow tray out from under the refrigerator. Itis starting to cause a smell when the fans kick on.
Most are not removable.Spray a little Lysol or diluted bleach(dilute with water) only put a little in the pan
Apr 20, 2009 | Whirlpool ED2FHGX Side by Side...
Rinse agent dispenser doesn't seem to be working
Keeping your rinse aid dispenser filled up may help, But ... By far the most common problem of white (mineral) deposits building up in a dishwasher is someone switched from a name brand to a generic, ultracheap dishwasher powder. I love store brand products and buy them all the time but when I bought an ultra cheap brand of powder detergent, within 5 loads of dishwashers the white build up showed up.
Switching back to a brand name powder like Electrosol or Cascade will really help.
The other thing you should probably do is pull the filter gear underneath the lower spray arm and clean out what ever has collected there. That is especially true is your dishwasher is making louder/different noise during the wash/rinse cycle.
Good Luck! Please report back here what you find, OK?
Apr 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
