Question about Insignia NS-LCD22-09 LCD HDTV
It says no signal in vga mode - Insignia NS-LCD22-09 LCD HDTV
  • 512 Answers
This means that there's no VGA source connected (i.e . a computer, a hard disk player, etc), if you want to use this input, you have to get a VGA cable (male to male DE-15 connectors at both ends) to connect both devices.
Posted on Mar 13, 2011
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Mar 28, 2014 | Computers & Internet
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Emachines T3516 won't boot and displays "no signal" message
If you're using a VGA monitor, select to start up using VGA mode.
May 20, 2012 | E-Machines eMachines Desktop PC
No signal is being picked up by vga from pc
Make sure you are in the right input, pc mode, so the VGA connector can pick up the signal.
Nov 11, 2010 | Westinghouse SK-32H240S Television
VGA input not working... won't work with a computer, but it has a vga input for this. has some kinda error message instead of displaying the computer graphics
You have to make sure that you set the computer to send out the VGA signal that does not exceed the TV resolution, otherwise you will get 'unsupported signal' error. You need to find out what the resoluttion the TV can do in PC mode.
Nov 10, 2009 | Televison & Video
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
No signal with vga input
I think there is a software upgrade for this problem. Contact Geek squad. This is a best buy store brand.
Apr 25, 2009 | Insignia LCDTV26 26 in. Television
No VGA signal on AOpen EPC945-m8
From your description, it sounds like once Windows starts it's switching to a video mode your monitor doesn't support. Try starting in safe mode or in vga mode, then check your desktop settings. Set the monitor resolution for 800X600 or 1024X768 at 60Hz refresh and restart. All recent monitors will support those rates, so you'll be able to get back to Windows.
Jan 24, 2009 | AOpen EPC945-m8 (95EP4596B1) Barebone
My LCD monitor is going into power saving mode
The monitor doesn't receive the signal from the PC. It is either the PC not booting up or the VGA coard is faulty. Change the VGA coard. or try reseting the VGA cord.
Sep 30, 2008 | LG L1915S 19" LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Insignia NS-LCD22-09 LCD HDTV Logo
126 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
