Hi my LG washing machine (WD-80485NP) has stopped working since this morning. The error code shown is: CL Any idea what that means?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
The "Cl" fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
Posted on Mar 13, 2011
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | LG Washing Machines
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
My washing machine gives a CL error code
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | LG WD-1280FHD Front Load Washer
CL error message
That means that your washing machines child lock is on. You can find two buttons Temp and Options in the panel. Turn the machine on, press these two buttons together for 3 seconds and thats should be it.
May 09, 2010 | LG WD-1080FD Front Load Washer
I have an LG washing machine - WM12336FD, it has come up with an error code CL. Can you please tell me what this means?
CL = Child Lock. Press both WASH and RINSE buttons at the same time and lold for several seconds to unlock (or lock),
Dec 18, 2008 | LG WD-1280FHD Front Load Washer
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Apr 09, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
