Question about Sony VAIO VGN-NR270N/S 15.4" Notebook PC
Sometimes the screen of the laptop become weired out & the screen becomes colorful, green patches override the pictures & the letters in black too becomes green in color, any portion s black in color appears green.Plz find me permanent solution for it.
  • Sony Master
  • 6,771 Answers
There are to things that come to mind, the LCD panel is bad, " will need to be replaced" or the video cable from the motherboard to the screen has come loose and will need to be reseated back into place. I would also suggest hooking a spare monitor to the laptop to rule out the video graphics card on the motherboard.
Posted on Mar 13, 2011
  • nick_merritt
    nick_merritt Dec 17, 2012
    I have had a similar issue. Where there was previously a black screen it is now green and white is pink. When I use an external screen the problem is removed. What do you suggest is the issue?
  • hgajardo Sep 07, 2013
    Same thing here... It works fine with the external monitor or screen share!
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
My tv lost picture and show only green screen although sound works
Hi, what you have is called hte "default " screen, the audio connection is apperebtly fine since you have sound, so the question is why video stopped. More than likely the video connection came loose somewhere, iI suggest retracing the " video connection " from end to end. If you're using an hdmi cable that has both audio and video cables combined-so it would be the cable or the player or jack on the tv's side that was defectice. if using standard " RCA " cables, those are the colors yellow, for video and red & white for audio. If someone or something become tangled in rca cables this may sometimes stress a connection and give a green screen ( with yellow cable still connected it will feel slightly loose ) I hope this helps ,good luck Prodzilla
Apr 10, 2011 | Sharp Televison & Video
TV will come on sometimes and sometimes not. When is does it is all red. When it does not is makes a wising sound and automatically goes off, display is still dark.
According to the symptom the problem is relate to the CRT. One of three guns (Red,Blue,Green) causing problem. When it becomes short set goes on standby and when the carbon removes after some times of rest it becomes on, So you need to find which color is missing except red because it is present as you said in your question, now check which color is missing Blue or Green in picture. The one which misses, is faulty gun and needs replacement.
Please let me know for further help by reply in comments column.
Thanks
Nov 24, 2010 | Apex Digital GB51HD09 51" Rear Projection...
Screen becomes red sometimes.
Try reinstalling the Display adapter from the recovery partion. Start>All Programs>Gateway>Restore Application & Drivers> Select the appropriate driver. Also update the display driverfrom http:\\support.gateway.com
Mar 12, 2010 | Gateway MD2614u Notebook
Problem with picture color
Magnetized The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 26, 2009 | RCA F27TF720 27" TV
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Sony KV 36FV27 green picture
when u have a specif color in screen it means the componenent´s (print borad, wires, transistor, ic....etc, are not conected to control ic) .....some problem´s become from short output transistor. but 80% become from bad joins..
Feb 04, 2008 | Televison & Video
Television cannoy be turned on
i think you have weak picture tube. when gun becomes faulty this happens. Measure Red -Green-Bluue cathode voltages. and filament voltage.if everything is perfect then the problem with your picture tube assembly. Contact service centre for further rectification
Dec 22, 2007 | Televison & Video
Greeen!!!!!!!!!
You can try to Degauss the monitor. It still sounds like the video cable is bad. That last part you mentioned about the OSM (on-screen Menu) having normal colors comes from the monitor and has nothing to do with the cable or pc. That tells me its the video cable, or the video cable connector (pins maybe bad) or a bad connection somewhere. There could be a bad connector inside the monitor where the video cable is attached to the electronics board. Sometimes those contacts just get oxidized and quit transmitting a signal. They need a good cleaning.
Jul 01, 2007 | HP Pavilion M703 17" CRT Monitor
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony VAIO VGN-NR270N/S 15.4" Notebook PC  Logo
469 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
