Question about Refrigerators
Our fridge works continuu and makes a strange and louder noise than usual.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 13, 2011
I have a GE profile pfcs1njwass fridge making a whistling noise. I read somewhere that the part responsible for this was recalled and ge will replace it free. Does anyone know anything about this.
Sounds like either the expansion orifice or the evaporator fan. Take a mechanic's stethoscope and place the probe on the evaporator tube(s). It will be louder on that if it's the orifice. Sometimes they will make a sound if the system has too much refrigerant charge. Either case unless you are a fridge tech suggest have a tech do this one for you.
Occasionally the evaporators get an ice build-up which can cause strange sounds.
Maybe as a last ditch test before you replace the fridge, try defrosting it overnight.
Jan 16, 2018 | GE Refrigerators
I have a IOTA DLS 45 that is making strange sounds. The strange sound is variable and stops altogether at times. Is it the fan that would be making this noise? If not what else could it be?
About the only thing that could make noise is the cooling fan. Does it sound louder when you've just hooked up and started charging the batteries? When you've got a lot of things drawing 12v DC power? Only other noise might be arcing by a short circuit or crackling of a fire!! ;)
Mar 03, 2017 | RVs
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
Fridge kicks in louder than usual for 20 seconds and clicks off.
the pistons in side the compresor are compermized.as long as the unit contiune's to work's than you are good.there is nothing you can do to fix this.
Nov 28, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Fridge making burbling noises
This could be two things, i have had fridges get louder with age, its the refrigerant returning to the compressor after condensing, but it could also be because its low on refrigerant. If the fridge is cooling normally and not having an issue getting cold then i would just leave it alone until it has further issues. Most places don't service them anymore, if your really really lucky you might find an appliance repair place that can send a tech out to check the refrigerant on the fridge, but the rule of thumb unfortunately is they are a sealed system, and if they get low its because they have a leak, and the leak is usually due to seals wearing out in the compressor, and a new compressor costs more then a new fridge!
Jan 11, 2018 | Frigidaire FRT17G4B Top Freezer...
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
Fridge Freezer issue
If it is a HMMMMM...CLICK sound it is the relays. (approx. every 30sec or so).... OR, condensor fan located next to the compressor.... Otherwise it is more than likely the fan(evap Fan)!
Goodluck,
Brian
Jul 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
