Question about Sony XVM-H65 6.5 in. Car Monitor
I installed sony xvm-h65 headrest monitors. The monitors powers up but does not show the DVD playing. The RCA connection from th DVD player is fine as it works with the previous monitors (one of them was still working). The SONY XA 113 connection box just does not want to convey the DVD info. I have connected the ACC wire to the 'ACC ON' power circuit. The black wires are connected to the ground and the red 'Always ON' wires are not connected as the monitor is receiving the power form the ACC 'ON circuit.
4 Suggested Answers
  • 47 Answers
SOURCE: Both displays doesn't power on anymore
OPEN THE UNIT AND MAKE SURE THE WIRES ARE CONNECTED INSIDE
Posted on May 13, 2008
AUTOSOUNDINS
  • 232 Answers
SOURCE: conect power
U MUST HAVE SPECIAL WIRE HARNESS FROM SONY SYSTEM
Posted on Aug 28, 2008
SOURCE: Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Posted on Aug 05, 2011
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
Power Acoustik DVD headrest shows blue screen/red welcome on start, won't play
sd sa dsa das dasd as fasf as
[url=http://www.rezibis.com/]headrest monitor[/url]
[url=http://www.rezibis.com/]headrest dvd player[/url]
Jan 02, 2013 | Car Audio & Video
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Conect power
Aug 20, 2008 | Sony XVM-H65 6.5 in. Car Monitor
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
Jan 29, 2008 | Sony XVM-H65 6.5 in. Car Monitor
Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
Sony XVM-H65 6.5 in. Car Monitor Logo
121 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
