Question about Dishwashers
STH903 smeg dishwaser,could someone advize me on how to attach the front panel to the door .I have lost the sheet which has all the directions to show me where to drill the holes etc. Thankyou Terry.
2 Suggested Answers
  • 204 Answers
SOURCE: how do you level the smeg dishwasher SA8210W?
No need to meove the door. Should be small silver legs on the bottom and use a wrench to raise or lower the machine.
Posted on Feb 06, 2010
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
How do I change the outside door latch on a smeg integrated washer/dryer
Go to www.repairclinic.com and enter WDI12. With luck, you will be presented with a list of common repair parts and may be able to view a generic Smeg video showing disassembly
Jun 20, 2017 | Smeg WDI12 Front Load Washer / Dryer
Started my washer with the water off and I cannot get the door open or start my washer even after turning the water on. Can someone offer a solution.
This may only be a momentary program glitch. Your intial steps should be to unplug the washer for AT LEAST 30 minutes in order to reset the Central Control Unit (CCU). Often this will correct minor program glitches and return the washer to normal operation.
If the door remains locked and will not open, the following link explains how you can use the manual release to get the door to open:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
For future reference: If the wash tub had water in it, you may want to try using a wet/dry shop vac to pull a vacuum on the drain hose to try to pull as much of the water (if any) ot of the wash tub BEFORE opening the door.
Does the front panel display any error codes? Usually an error code is generated with any interruption in operation of the washer program. If so, the error codes are NOT listed in the Owner's Manual. For a complete explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this problem.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Jun 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he3 model#110.42822201 washer; where can I get a schematic? Graham
Every one of these front loaders come with a technical data sheet inside. You need to remove the lower toe panel directly below the door to access it. The screws are located under the bottom front edge of the washer. You may have to prop the two front feet of the washer up to access them (a 2x4 works well for this). With the screws removed, the panel will drop down, then come off. The tech sheet will either be located directly behind the panel, or affixed to one of the interior cabinet walls in an envelope. The tech sheet includes all troubleshooting data, error code definitions, diagnostics procedures, test points and wiring diagrams. I hope this helps you.
Jan 30, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
When I try to start my washer it beeps and flashes f then dl. I lost the owners manuel. What does this error message mean and how can I fix it?
The error codes are not listed in the Owner's Manual, they are listed in the Technical Data Sheet. "Fdl" is a door latch error code. This is an indication that the door latch is broken or the Central Control Unit (CCU), which controls the latch is not working properly. The technical data sheet that comes with the washer explains all the error codes, diagnostics steps and troubleshooting procedures on how to determine which component has failed. The tech sheet is located inside the washer behind the lower toe panel directly below the door. If not directly behind the toe panel, it will be affixed to one of the interior cabinet walls. To remove the toe panel, you need to locate and remove the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: For better access to the toe panel screws, you can prop the two front feet of the washer up. (A 2x4 works well for this).
Inspect the door of the washer to ensure the latch pin is intact and not broken. Then, inspect the latch mechanism on the front of the washer to ensure nothing is lodged inside. Last of all, remove the top and panel of the washer by locating the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. Locate the connector plugs that run between the CCU and the door latch. Unplug each connector (one at a time) and plug them back in to make sure they are seated properly and making good contact.
If you determine the latch is broken, the following link explains the steps necessary to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions, please let me know. I hope this helps you.
Sep 25, 2009 | Kenmore Elite 45986 Front Load Washer
Door mechanism broken
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Washing Machines
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
