Question about Akai PT4298HD Rear Projection Television
Tv won't turn on
Hi do you have schematic for this tv can you share I need it to fix the power supply.
Thank you
  • fjzepeda Aug 02, 2008
    Hi
    slinteriors do you have schematic for projection tv model pt4298hd I need to fix the power supply also give me tips
    thank you
  • Anonymous Aug 18, 2008
    tv will not turn on
  • 13,433 Answers
I don't have a schematic for it - I will see if one is available or for sale.
I recommend you also ask one of our best tv experts silinteriors he may have the schematic
http://www.fixya.com/users/slinteriors
Posted on Aug 01, 2008
PS3 3D TV Display Doesn't turn on 2 red blinking lights
HI, in this video you will find how to fix your Sony 3D Display
https://www.youtube.com/watch?v=OdPGSZnTIPw
Dec 02, 2012 | Sony PlayStation Televison & Video
Tv won't turn on. replaced bad caps and after some testing it turned out that the power supply board wasn't giving the supposed voltages.
This problem is not easily to be solved.Tries to changes all the capacitors components even if u think is good around the bad capacitors surrounding area.After that,if u still have the same problems.This problem could be any high voltage components parts like transformers to ICS power regulator.Trying to fix this power supply board probably beyond your ability and u must also have the tv power supply board original schematic and electron scope too . .To measure those power transformers and ics power regulator output.Tries websites like Shopjimmy.com,EBay.com to buy a whole new refurbish tv power supply board for the replacement that is ur best bet.
Sep 27, 2012 | Insignia NS-LTDVD19-09 LCD TV
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
Help new power supply will not power up.
if you had a surge, it could have damaged more than just the power supply. When you plug in the unit, does the power indicator light up??? your main board could also have damage. The main board sends a signal to wake up the power supply thus turning on the TV. If you have to replace the main board as well, it probably won' t be economical to repair the set.
May 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
Tv wil not turn on, either by remote or by Power button?
Hello douglastrame,
Welcome, and thank you for using FixYa!
If you are sure the TV is plugged in, then there can only be a few other remaining reasons why the TV won't turn on.
1. 5V low or high voltage power supplies are burned out.
2. Entire power supply is burned out.
Here is the part needed from eBay!
Power Supply Board
http://www.ebay.com/itm/VIZIO-VA26L-Power-Supply-715T3003-2-91324QA7-/370498439650?pt=LH_DefaultDomain_0&hash=item56436d89e2
Order it and install it yourself, if you believe you can. Or take the part and the TV to a local TV Repair Shop to have it installed for you.
Have a great day!
Sep 11, 2011 | Vizio VA26L 26 in. LCD HDTV
Hi, I still own a Sharp VCR Model no. VC-H670X. Has been too good to part with. Unfortunately, it won't power up. Having a technical background, I have found that there is power on the primary...
Hi, I would say to you get rid of it. In this time of HDTV's You will no longer be able to record a program with it. It will all be in Digital. But you can still play a video. To record a digital program you will need a PVR (personal video recorder)or DCT.
Check the plug for power. Use another plug.
If it cost more to fix it, you better think about it some more. Good luck.
Jun 16, 2011 | Televison & Video
Boss psa 120s automatically shuts down and does not turn on
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Jul 08, 2009 | Boss PSA-120 (761294015735) Power Supply
Hitachi cmp 4121
Hello naomi1972,
If you checked the fuse, and it is good but the set remains off, this is an indication that you primary power supply has a problem. At this point you will need to have the schematic diagram to check the voltages on the power supply board. If you have a background in electronics you can do this with no problem, however if you do not have a background in electronics, I would suggest that you have a qualified TV repair person fix this TV for you.
My diagnosis of this TV is that the power supply board may be defective. This is the best I can offer with the information given.
I hope this helps,
Thank you,
Shuttle83
Jul 18, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Plasma went black. Power not interrupted.
Vladislav fixed his TV already by replacing some defective capacitors in the power supply.
The locations of the defective capacitors are C523 and C524. The value is 0.22uF/400VDC or can use 0.22uF/600VDC Polyester coated.
Good Luck.
Mar 03, 2008 | Samsung HPN5039 50 in. Plasma HDTV
Akai PT4298HD Rear Projection Television Logo
95 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
