Question about Dryers
Hi, The dryer keeps stopping. Not sure what I need to press to keep it going?
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Mar 13, 2011
The buzzer on the dryer keeps going off when i go to start the dryer and dryer wont start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Apr 23, 2012 | Amana NED5100TQ Dryer
My dryer Bosch model number WTA3003GB/01 will not keep turning after being switched on. It works if the switch is pressed in but stops as soon as the switch is released.
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Dryers
I have a kenmore dryer, model 41781142000. The timer will not turn off. It just keeps going. The dryer only turns on about every 10 minute for about 2 seconds and stops. When the timer gets to the off area...
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 23, 2010 | Dryers
MY SIMPSON MAXIDRY 362 3.5KG HEAVY DUTY DRYER KEEPS OVERHEATING AND CUTTING OUT. WHEN IT STOPS AND I PRESS THE SAFETY SWITCH IT TURNS ON AGAIN BUT ONLY FOR 10 MINUTES. CAN YOU ADVICE ME ON WHAT I CAN DO...
I would check the exhaust pipe outside and make sure it is not blocked and has good strong air flow while the dryer is running. If there is not good airflow, then clean out the exhaust hose and pipe. There could be other problems, but I would start with this.
May 01, 2010 | Dryers
GE Dryer works but keeps stopping after only 5 minutes
IT SOUNDS LIKE YOU NEED TO REPLACE TERMOSTATS.
Oct 19, 2009 | Dryers
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
