Question about Maytag MSD2758GEB Side by Side Refrigerator
The refrig is not cold enou gh.. I've turned it up to 8 and my crisper temp is getting higher (50)
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
GE side-by-side not saying cold
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to temp setting .
May 26, 2010 | GE GSS22JF Side by Side Refrigerator
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
We have a haier air conditioner window, model number is HWR05XC6. It worked good last summer brand new and just put it back in the window for this year, and turned on the remote control the only thing that...
Dear Amy Rodger,first change your batteries, probably not enou gh juice. Dear Guest, around here in Oklahoma, dirt dobber nest always stops our fan blades from turnnings. Give it the ole once over.
Jun 02, 2008 | Heating & Cooling
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Maytag MSD2758GEB Side by Side Refrigerator Logo
48 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
