Question about Toro Lawn Mower With Toro Power Tools
TORO MODEL#20041 WILL START BUT WONT STAY RUNNING UNLESS I CONTINUE TO PRIME. AFTER ABOUT 1 MINUTE OF CONTINUOUS PRIMING IT WILL STAY RUNNING. RUNS FINE THEN
  • 246 Answers
SOURCE: can't start toro mower. cleaned spark plug , new
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
wadembly
  • 513 Answers
SOURCE: I have a 6.5 hp toro lawn mower. starts, but
the diaphram in the carburator is bad or broke which is behind the primer they brake or rip the will not keep gas flowwing through try that
Posted on Jun 06, 2009
SOURCE: mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
Posted on Sep 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Toro model 20007 recycler with a 6.5HP Tecumseh engine
This almost sounds like a pinhole in the primer bulb but I need to know if you did the following. Did you remove the jet and venturi tube in the bottom of the carb. and clean the BRASS orifice hole and BRASS tube holes? If you did not then It will act just like the symptoms you described. Also check to see if your float bowl nut has holes in the side of it. IF it does then make sure the hole(s) are clean. Also make sure the fuel selector is all the way ON. Adittionally if the carb to block mating gasket is torn or not secure it will also perform as you stated.
Lastly the open the fuel air mixture screw on the side of the carb about 1/8th turn and see if the performance changes.
If the problem persists ....
This is dangerous due to the risk of fire but....
If you have any carb cleaner you can give it a quick shot in the nmating areas just after you start it before it gets hot to see if it speeds up. If it does, you have a vacuum leak. It is better to use an unlit propane torch if you have one.
Thanks for using FixYa,
Kelly
P.s. If the problem does persist I will need your complete engine number to proceed in troubleshooting.
Posted on May 21, 2010
Testimonial: "Thanks for the info. I ordered a rebuild kit for the carburetor so i can replace the gaskets. And i ordered a new primer bulb. The engine is a Tecumseh LV195EA-362003B 6.5 hp engine on a Toro model 20007 recycler mower. Do I need to remove the welch plugs?"
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
My lawn mower will start but will not stay started. If I continue to prime it it will go but as soon as I stop priming it it stops. I replaced the air filter, gas filter and spark plug and the problem...
I called my local Toro dealer about this problem and he immediately said "Oh, you've got a clogged carburetor". He directed me to tip the mower on it's left side, remove the air filter and just spray carb cleaner into the carburetor without removing the carb. He said it is common for a blade of grass to get in there and clog it. The pressure from the carb spray will usually dislodge a blade of grass. He also cautioned against removing the air cleaner assembly unless necessary. He said they warp easily and once you remove them, they rarely go back on cleanly ie without leaking, and you'll need to replace it. Also, if it's not too dirty, just adding Seafoam to your fuel can be very effective. For the $10 cost of a can of carb cleaner and a can of Seafoam, this worked for me.
Jun 26, 2010 | Toro Lawn Mower With Toro Power Tools
My lawn mower starts, runs for about 5 seconds and then dies. I need to prime it in order for it to start. It will keep running if I continually keep priming it. I have bought new gasoline, changed the oil...
The engine is starving for fuel, that is why it will keep running while you force the fuel to the engine with the primer button. At this point, the carb will have to be removed,disassembled and cleaned. I'm sure you will find blockage and dirt in the carb and also in the small orifices for air and fuel flow.
May 29, 2010 | Toro 89885 "lawnboy" Premium 4cycle Oil...
I have a Toro 6.0 GTS5 mower that starts on the first pull but will not continue to run. If i continue to prime it while it is running, it runs until I stop. Just had it serviced and Carborator rebuilt at...
SOUNDS LIKE IT HAS TRASH IN IT SOUNDS LIKE YOU NEED TO HAVE THE FULE FLUSHED AND THE CARB CLEAND I KNOW YOU JUST HAD THIS DONE BUT SOME PLACES DONT DO A FULL TUNE UP ITS BAD THAT THIS HAPPENS BUT IT DOSE I ALLWAYS DO A FULL TUN UP LET ME KNOW IF YOU NEED ME TO TELL YOU WERE A GOOD SHOP IS
Oct 11, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start toro mower. cleaned spark plug , new air filter . will run for 2 or 3 seconds on prime , then stalls ,will fire every time , but won't continue to run what next? 22" self propelled...
Hello:
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
My mower will start after I prime it with the bulb primer, 3-4 plunges, and the engine will rev very high and then slow down,sputter and then stop. I have to prime it again to get it to run, but it will...
hi paul,
sounds like you have a dried out diaphram in the carburetor. depending on your model mower it will be located on the carburetor on the side attached by screws or it could be on older mowers underneath the carburetor if the carb is mounted to the tank. in any instance priming the bulb then it dying out is a sur indication of this. i woild replace the diaphram (inexpensive fix) cople dollars or so and that should work. you can take wd 40 and spray carefully around the carb base or around the cover to the diaphram and see if it will run a little longer if it does sometimes this will lubricate a dryed diaphram and will allow it to continue to run at leastuntil it becomes dry again. but it may allow you to get some mowing done until you can relpace it. hope this helps!
Mar 29, 2009 | Toro Lawn Mower With Toro Power Tools
Engine will not stay running
Hi
When the engine stops check the spark at the spark plug.Check compression(remove the spark plug and ground the plug wire on the engine,seal the plug hole with your thumb.Operate the starter.If the compression preasure blows your thumb off the hole,the compression is adequate for the engine to run.Now priming the engine(put some gas into the spark plug hole,back the spark plug and try to start the engine.Let me know. savumihai71 regards
Dec 10, 2008 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
139 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
