Question about Casio PRG-40T-7 Pathfinder
How to calibrate 2271 prg-40? - Casio PRG-40T-7 Pathfinder
3 Suggested Answers
SOURCE: Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Posted on Sep 11, 2008
  • 11800 Answers
SOURCE: i have a casio protrek
No, this has nothing to do with the battery - the setting mode is either engaged or the defect is internal: the set/mode button is pressed and it doesn't comes out or the processor of the watch has failed.
Take out the battery, wait 15 seconds and put it back; now try to set it. If it fails then something is defective internally. Try to find out if a button is pressed - it's easier to spot it if you look at the rear, with the cap off - the button pins will be clearly visible. If all the buttons are ok then the defect is in the processor - the watch is dead.
Posted on Jun 12, 2011
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
How to use all finctions of prg 40
You can download a manual/instr from their website. You will have to enter in your country/ model info, etc. Heres the link:
http://www.casio.com/
Aug 19, 2010 | Casio PRG-40T-7 Pathfinder
I replaced all four batteries and i still have nothing .inside the watch it says to jumper the A C point with a twizers. what is the AC point and where.this s a casio 2271 2years old had factory batteries...
Casio battery changes are quite tricky.If you look closely at the watch module there is a place for the battery and a v-small depression usually circular on the silver module .There will be the letters AC in small writing.You need to touch the depression AC and the battery at the same time with a conductive tweezers.This shorts the module and re sets the watch.Make sure any seals go back in to protect from water/dust.
Regards
Aug 13, 2010 | Casio PRG-40T-7 Pathfinder
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
How do i change the batteries in my 2271
The safest option is to take it to a watch shop and ask them to change it for you.
While removing the back and replacing the battery,(assuming that is has a similar back to mine, which is the same make),is not too difficult, it can sometimes cause problems and since the charge for this is quite small, it is not worth taking any risk is getting it wrong. (Particularly difficult is making sure that the seal is properly made).
Considering the cost of you watch I would advise against doing it yourself.
Jan 25, 2010 | Casio PRG-40T-7 Pathfinder
Barometer ERR message on Casion 2271
here is the link for very complete manual:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2271.pdf
Download it and follow the instructions how to set and reset the altimeter and other features of your watch. Use zoom or magnifying tool, as the document originaly has tiny script.
Do not forget to rate please.
Feb 09, 2009 | Casio PRG-40T-7 Pathfinder
6 year old Casio no. 2271 has ceased responding to buttons
Hi, If you buy some new batteries - i.e. from ebay (very cheap) and replace the old ones - or take tyhe watch into a jewellers and get them replaced (appx. £15) this should do the trick. The batteries should be replaced every 2 years.
Jan 02, 2009 | Casio PRG-40T-7 Pathfinder
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Casio PRG-40T-7 Pathfinder Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
