Question about Toshiba Televison & Video
Don't know how to get the dvd to play. Looks like the disc is playing but can't get it on the tv
  • 500 Answers
Please check if the AV cables (yellow, red and white colored ends) connections are correct, at your TV you must select the input where the AV cables come from your DVD.
Posted on Mar 13, 2011
Make a dvd on a computer to play in a dvd
Hi, Somewhere in your windows dvd maker there should be an option for you to "Finalise" the disc, or it should do it automatically.
The other problem you may have is the disc is finalised but your player under the tv does'nt play "dvd+r" some only play + or -.
Hope this helps.
Jan 27, 2015 | Televison & Video
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
Down loaded flip video to disc. Disc will not play on TV but will play on computer
Hello. There are a few factors as to what would allow or disallow the disc to play. The main reason is going to be the file type the video was saved as. Your computer will have an easy time playing because it can recognize the file type. As for DVD players or TV's with built in DVD players the device will have be able to recognize the file type and know how to play it. For example some DVD players may play a DivX movie but not an AVI. So your player probably doesn't recognize the file type you are wanting it to play. One other possibility is the disc wasn't finalized when burned.
Mar 06, 2011 | Cameras
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like Ebay.com or Amazon.com buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
