Question about Tefal FV9342 Iron with Auto Shutoff
Tefal fv9240. No power, no heat. suddenly gone off while ironing. what do i do?
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
  • 1019 Answers
SOURCE: tefal Aquaspeed 150
yes unless the thermostats gone.
It,s not really financially practical to replace parts, will cost you parts-and labour.
cheaper to get a new iron, unless still warranted.
Mike @ Compurepair.
Posted on Feb 22, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
  • 1214 Answers
SOURCE: red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Posted on Jan 30, 2009
SOURCE: how can i clean my tefal iron/ surface
tough soapy sponge
Posted on Dec 27, 2009
Our Tefal Aquaspeed110 Iron will not turn on when we plug in the power chord. Is there a fuse that needs to be replaced? If so, where may we get one and where in the iron do we find it please? Karl...
Majority of the iron don't have fuse, you should check the plug and cord. Often it is become open meaning no continuity circuit, no heating. To be able to check it unplug, you should use a analog tester. Also check thermostat dial control, when it is not in right adjustment it is also cause a no heating symptom.
Good luck.
Jul 17, 2011 | Tefal Aquaspeed 155 Iron with Auto...
There is no heat from the iron. Happened all of a sudden
Guess the heating element has burnt out. Or open it up and checck if the power is being delivered to the element. If being delivered then then the coil has burnt out.
Apr 20, 2011 | Tefal UltraGlide 1749 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Not heating up, flashing light
It sounds like you have a loose wire, check your plug to make sure the wire connections are sound. The loose connection may be where the wire enters the iron its self. For saftey I would have this repaired by a professional or have it replaced.
Dec 04, 2009 | Tefal Irons
The auto stp security light is on and the iron does not heat up i have a tefal ultra glide iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
Sep 16, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal pro express turbo water flowing out of iron and soaking the clothes
i have a tefal pro express gv8110 iron and it keeps leaking out water onto the clothes and doesnt seem to heat up. i have only had it for 22 months so im not sure why it has been doing this. it also doesnt seem to let the steam out like it used too. please could u help me
Sep 08, 2009 | Tefal Irons
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Aquaspeed 150
Mike @ Compurepair.
Oct 01, 2007 | Tefal Aquaspeed 170 Iron
Tefal FV9342 Iron with Auto Shutoff Logo
192 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
