Need to install replacement monitor on laptop. Need to know how.
  • 500 Answers
Look for the VGA output, there you'll connect the external CRT or LCD monitor signal cable (VGA input), at the funtions keys (F1 to F12) find the one that has a monitor or screen icon, it activates using the Fn and the found funcion key.
If you are replacing the LCD panel, the first step is to check if the screen frame has covered screws (commonly there are two), if it doesn´t have them, the frame is only set by inner clamps and can be separated with your nails and fingers carefully, after removing the screen frame you'll have access to LCD panel that is assembled usually in a metal frame, look for all the screws that hold panel, also carefully identify and disconnect all the cables that the panel uses. Look for the LCD panel model, but also you can buy it using the make and model of your laptop, to install it follow the reverse steps of above.
Posted on Mar 13, 2011
Running bios/boot menu through external monitor
Even if you press F8 and use the boot menu, you will need to type the administrator password. The other alternative is to use a Win OS disc and reinstall from scratch using the COA number underside of your laptop.
Jan 18, 2014 | Computers & Internet
I have a Toshiba Satellite L650 laptop connected to an external monitor. When I use the monitor, the video display is fine. But if I try to use the laptop w/o the monitor, everything is really dull and...
I think you know the answer, the LCD is going bad. They are replaceable but the costs are in the $75-100 range plus labor to install it. Is your current system worth it??
I do this for fun & feed back not $$$
Jim
Oct 03, 2011 | Computers & Internet
3680 hard drive failed, then replaced, installed Win XP Pro. Sceen non-fuctional, but will operate with external monitor. Do I need drivers or is the screen dead? Thanks, Terry M.
Hi Terry,
Basically you dont need any drivers for the monitor to make it work, as you noticed even if you dont install a driver the monitor will still open for ypu to use it, the problem your facing right now is that the lcd of your laptop might be faulty. the good thing was you can still able to use an external monitor. Just back up the files and bring the computer to a depot so that they can replace the LCD
Thanks for usng Fixya
Jan 24, 2011 | Acer Aspire 3680 Laptop
Display is very dark seeeems to gradually worse. Problem started after win7 install
Tried connecting the laptop to an external monitor and press fn f8 and let me know if you get any picture? If you do you need to replace the back light inverter or the screen.
Thanks,
Dec 18, 2010 | Acer TravelMate 4021WLMI Notebook
I'm getting wavy lines on my monitor. When I go into the menu of the monitor itself there's no lines so I'm thinking it's something with the computer itself. Perhaps the video card is going bad?
That's possible. I've had people send monitors in for service because of lines or distortion, but since the lines don't show up when they print they figure it's the monitor's fault. A new video card fixes that. Or the monitor might be at fault.
Test the monitor with another computer. If you don't have more than one, get a friend to bring over a laptop. Except on Macs, the external monitor connector on laptops is a standard VGA type, so you can plug your monitor in. If there are still lines, you'll know it's time for a new monitor or to see about service.
If you need a new video card, make sure you get one that will fit your motherboard. There are different slot types for video cards (PCI slots in older computers, AGP slots in newer ones, and PCI-E in the latest versions). This page can help you figure out which you have if you don't already know. Once you get a replacement card, all you need to do is plug it in to the appropriate slot. The motherboard will detect the new card and start using it. (I'm assuming you'll be installing a card where there wasn't one before. Most consumer computers have integrated video and that's what you're replacing with a plug-in card. If your computer already has a separate video card, obviously you'll just swap the old one for the new one.) Also - this will sound obvious but it's amazing how often it's overlooked - you need to connect your monitor to the video connector on the new card. People sometimes plug their monitors into the integrated video connector out of habit. On some motherboards the integrated video still works when you plug in a new card, but on others the on-board video is disabled. Then you either have the same bad video, or none at all.
With a new video card, your display may look funny when you start Windows the first time. Until you install the drivers that come with the new card, the color depth and resolution settings may not be right. But with the right drivers installed, your display should be back to normal.
Hope this helps. Thanks for using Fixya!
Nov 30, 2010 | E-Machines eMachines Desktop PC
Ive got green lines running down the centre of laptop
Just want to know if the lines only appear in windows? try booting in bios setup check if the lines still appears. if not then uninstall the video driver then install latest version. if the lines appeared in all occasion then test laptop using an external monitor toggling the display Fn + F8 if no lines in external monitor replace you laptop lcd panel and lcd cable + inverter. if the line appeared in external monitor replace the mobo or video card.
Mar 22, 2010 | Dell Inspiron 1501 Notebook
Installing dual monitors
You need to have a PC or LAPTOP that supports DUAL MONITORS mode.
On most Laptops, dual monitors is fairly standard: LCD laptop display and external monitor plug to your VGA (or HDMI) output port.
On Desktop, you need to make sure that your current adapter support two external monitors outputs or you will need to install an additional plug-in display adapter.
If the Hardware requirements above are met, then it is a simpler matter to change your 'display settings' to enable the second monitor either as a mirror of the main display or as an 'extension' of the main display.
Hope it explains what is required! Let me know how your go.
Dec 30, 2009 | Computers & Internet
How to install monteror Q19wb without a CD
1. A lot of Laptops will be able to detect your monitor as a plug and play device.
Try hooking up the monitor to the laptop's VGA (Blue port with 15 pins in three rows of 5). You will need a vga cable to do this.
Once the monitor is connected and both devices are powered on check your laptop keyboard for a key or button with a picture of a monitor or CRT/LCD written on it.
Often this will be a secondary function key. (On my laptop you switch displays by hitting the Fn key and F8)
2. If this doesn't work you may have a problem with the video card and might consider sending it to the manufacturer for repair or getting a replacement (not a novice task)
If its still under warranty you can probably send it in and get the LCD or Video card replaced.
I see that this post is quite old, and you have probably found an alternate solution by now, but I hope that you or someone else finds this information useful.
Dec 11, 2009 | Optiquest Q 71 17" CRT Monitor
Red Green stripes on IBM Thnikpad T60p tft monitor
Those are dead pixels if you want to get rid of them you will probably need to replace the monitor. They will probably charge you an arm and a leg to replace it so you might get a second quote from Computer repair shop.
Jan 31, 2009 | IBM Lenovo ThinkPad T60p Notebook
How can I hook my tower up to my laptop to update information?
There is a blue (usually blue) 15 pin video connector on the back of the laptop, just connect the video cable from the monitor to this connector, and when you boot up the display will switch to this monitor.
Windows Media player need a Codex plugin to play DVD's. If you install a DVD play program such as PowerDVD it will install the Codex plugin, then you will be able to play DVD's with either PowerDVD or Windows Media Player.
Jan 22, 2009 | Compaq Evo N1020V Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
