Question about Frigidaire Freezers
Model no. FKCH17F7HWC frigidaire freezer/refrigerator has loud fan
2 Suggested Answers
  • 82 Answers
SOURCE: refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Posted on Jun 14, 2009
My Frigidaire commercial freezer model LFFH2067DW1 makes a loud, almost rhythmic, knocking sound. What can that mean?
Could be a compressor on its way out, a warped or clogged fan could cause similar sound issues, the valve plates in the compressor could be worn causing pressures issues.
Nov 15, 2014 | Frigidaire Freezers
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
My refrigerator's inner fan was making weird noises. After some time I poked it and then it stopped moving. The fan is now unable to turn. What should I do?
Two things could be wrong. Motor bad or frozen up with ice.The noise could have been
from frost building up and hitting the fan.If this is the case you need to defrost. Even self
defrost models do this some times..Empty freezer and run a hair blower (dryer) to put heat
in the compartment. this could take a while to do. over night...So run blower for a while to heat up the freezer then shut it off, close door .let sit It takes time for the heat to get to the ice.
if the motor is bad you will have to take inside cover off the access the motor
Oct 13, 2010 | Frigidaire Freezer Refrigeration White...
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
149 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
