Question about Pioneer TS-W304C Car Subwoofer
I cannot find the right way to hook my TS-W304C Subwolfers up to a mono channel amp.
    Genius:
  • 1,066 Answers
What amp? the speaker wiring depends on the ohmage rating of the amp. if the amp is 2 ohm stable, then you can hook 2 TS-W304C's up to it, both positive leads from the speakers attached to the amp positive, and both negative speaker leads connected to amp negative. this is called parallel wiring, and it reduces the ohmage (resistance) down to 2 ohms. your speakers are 4 ohms, and 2x4 ohm speakers in parallel makes it equal 2 ohms. if your amp is only 4 ohm stable, then you will only be able to hook up one of your speakers to it.
Posted on Mar 13, 2011
  • kjw2569 Mar 14, 2011
    I'm hooking it up to a 250 Wt mtx amp.. I have no idea how many ohms that is. You think I will just need to Parallel wire it still?
  • Matthew Spark
    Matthew Spark Mar 26, 2011
    i need the model number of the amp. it is likely 4 ohm stable (means you can only hook up 1 of the subs), but could possibly be 2 ohm stable.
I have a QSC RMX 2450 in which both channels are driven even though the amp is in stereo mode and I am only sending a signal into input channel one. It acts as if the amp is in parallel mode but I have...
My thoughts are that the amp has a poor channel separation but usually you can only hear a very quiet trace of the sound through the undriven channel. I agree with Taurus and make sure that the switch is making contact and moving all the pins to the proper points. This is a Home stereo amp, it comes with an extended 6 year warranty if you register it, I would check into getting a warranty repair before doing anything to it! Looks like a nice quality piece, those dip switches are a little bit confusing but the way it's built it is necessary to have them. It has a Dual Mono amp section so there is no way that any sound can be crossing over unless the swithches are directing it. The only way that can happen is in Parallel or in Mono. You could be in Stereo / Mono which would input both channels and output 3 settings a 1, 2 in Stereo & a Mono, Try hooking a speaker up to the Mono/ Bridge outputs and see if it's louder than just hooked up to 1 or 2. Parallel inputs will give you Mono 1 & 2 with Bridge off, and might give you Mono 1 & 2 with a bridged Mono if the bridge is on, like 3 channels all mono with one getting twice as much power as the 1 & 2 will put out. Although they have it labeled to not use it in those settings it's possible to do. I can see why you would be checking the switches.
It may actually be labeled incorrectly , as strange as it seems, many Chinese products have been made with labeling errors. Plus and minus have been wrong on Asian Made car amps so it's not that inconceivable that this may have some incorrect settings shown?
Apr 03, 2013 | Car Audio & Video
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
What amp for a Pioneer TS-W304C 10 inch
Wow, i just answered a similar question so, pretty much the same answer.......
Your speaker, based on the model number you provided, is rated at 4 ohms .Nominal power handling range is 300 watts. And a peak of 600watts. That does not mean start cranking 600 watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms. Leaves you a little headroom on the amp, but use caution.
Jan 05, 2013 | Pioneer TS-W304C Car Subwoofer
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
How do I hook up mono amps in a two channel stereo system. Speakers are two way bi wire capable. Thank you
Your question is not very detailed but you should use one mono amp for the L channel and another for the R channel. Don't bother with any Bi-wiring.
May 03, 2010 | Kenwood Audio Players & Recorders
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Pioneer TS-W304C Car Subwoofer Logo
93 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
