Question about Whirlpool MH6150XL Microwave Oven
It comes on and appears to be working except that the sound has changed. Then I took the food out and it was not hot.
Mc25ss everything working apart from the food getting hot sounds ok food just cold
Sounds like the high voltage fuse or the magnatron is faulty,do not try to repair your self unless you know what you are doing
Sep 14, 2014 | Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
Everything seems to be working except food won't get hot
your 5kv fuse connected to the magnatron is probably blown..it looks like a white casing with two wires coming out of it..fuse is inside this..be careful please
Apr 21, 2010 | GE XL1800 1100 Watts Microwave Oven
Food does not get hot
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 22, 2010 | GE Profile Spacemaker Over-the-Range...
My microwave turns on but the food isn't getting hot.
Sounds like a magnetron failure. This is the device that generates the microwaves that heat the food. It is connected to a lot of high voltage components and if you don't know what you are doing can really hurt yourself. Typically these parts short out and it needs to be replaced. The cost of replacing the magnetron come close to the cost of a new oven. Not usually cost effective to repair.
Dec 23, 2009 | GE Microwave Ovens
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Motor sounds differently, smells like something is getting hot, won't heat the food
Do you have good air flow coming out of the vents?
If for some reason the cooling fan stopped working, it can cause the magnetron to overheat and be damaged.
If you don't still have your manual, you can download it here:
http://www.geappliances.com/service_and_support/literature/
It will address ventilation issues.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH6150XL Microwave Oven Logo
85 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
