Hi i have lennovo g990 my keypad is locked could any body help me
  • 84 Answers
Yes, this should help you.
http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQKLQ.html
If it does not, look for the Function key (Fn) and look for a lock sign. Hold function and then press the lock key.
Posted on Mar 13, 2011
How can i lock the keypad?
Hi Eliza,
Enabling and disabling the embedded numeric keypad
Press fn+num lock to enable the embedded numeric keypad. Press fn+num lock again to return to standard keyboard functions.
NOTE:
The embedded numeric keypad will not function while an external keyboard or numeric keypad.
Thanks Hope this helps!
Don't forget to rate:)
Gary
Apr 05, 2016 | HP EliteBook 2530p Notebook
Is there any app for nokia 6710 navigator cell phone to lock my messages folder or set a code on keypad lock?
If there is no security lock for keypad in the features of phone,,,follow this site Nokia Store: Download LockOnGallery and many other games, wallpaper, ringtones and mobile apps on your Nokia phone.Download it and install it to your phone.The benefit of this application is to lock the gallery and keypad with a specific security code.You can edit the code when it ask you to enter.Good luck
Mar 21, 2012 | Nokia 6710 Navigator Cell Phone
I got a 2000 Ford Explore that I got about 5 months ago. I don't know the codes on the door to unlock it. how can I get the codes or reset it.
You will need the original factory programmed keyless entry keypad code to program your own code. To locate the original keypad code, open the right/rear door. Pull the on-body rubber weatherstrip out, around the rear side of the door closure. Fold the right/rear seat back down into the locked position to facilitate access to the right/rear seat belt anchor. Carefully pry the upper plastic panel that houses the height adjuster and seat belt anchor off the body taking care not to damage the panel. Now pry the lower panel outward just far enough to enable access to the Vehicle Security Module, where you'll see three electrical connectors plugged into it, colored green, gray, and blue. On the module will be a series of digits on a label similar to 2L2T-15K602-EA. Beside those digits are five numbers. Those five numbers are the key-less entry keypad code. Once the original keypad code has been obtained, you will need to enter it, press the 1/2 button within 5 seconds to activate the programming mode. Holding the 1/2 button for more than 2 seconds after activation will erase the the code you programmed. The existing code will not need to be erased to program a new code. Within 5 seconds, enter the new 5-digit keypad code. The door locks will lock and unlock to confirm the new code is programmed. Hope this helps Tim
Apr 06, 2011 | Ford Explorer Cars & Trucks
Mobile model:1662-2 I have put security code for keypad lock.but my friend enter wrong code for 5-6 times.now i can't access it even entering right code.what to do.my keypad is locked.
Hi I want to put the security code to my cell b'coz some body miss used my cell but i don't how is it can you help. i don't know the procedure?
Dec 20, 2010 | Nokia 3110 Cellular Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
I am wanting to instal more RAM into a Laptop "Acer Aspire 3503". Where is the RAM situated? What panels need to be removed? Regards Ron
Hi ,Your laptop memory is found directly below the keypad.So you guest right-you will have to remove the keypad to get to the memory.When you flip the laptop over you will find the keypad screws marked with small keypad immages.Make sure you find them all and do NOT force the keypad off.Some keypads are also locked at top of the pad looking from the front.You can release them with a small screw driver.Also take great care not to rip the keypad cable open or off when you lift the keypad up and downwards-it has a lock peace securing it in the connecting socket,which you must lock again when you re-install the pad.Also remember not to touch the copper connections of the memory cards during the installation process.{static electricity of your body will damage the electronic gates on the card,rendering it useless.The memory clips in place and is locked on the sides,which you have to release before slipping the old cards out.If you are only adding a card,make sure it lock into place.Regards Georgeo
Jun 03, 2008 | Acer Computers & Internet
Nokia 1100 keypad lock code
i have a nokia 1100 ,its keypad lock no not working / please advise me to unlock the keypad.....
May 03, 2008 | Nokia 1100
Keypad lock with code
I am sorry but this function is not present with the Sony Ericsson K530.
Mar 20, 2008 | Cell Phones
Motorola razr keypad seems locked???
It seems your Keypad Flex is messed up. common issue on the v3 - we can fix this for you - $25+ shipping
http://horizonwirelessonline.com
Jan 21, 2008 | Motorola Mobility RAZR Cellular Phone
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
