Question about Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
I have a brand new wild thing chain saw and was using it today in the yard and it threw the chain,I put the chain back on the correct way and now the chain will not turn,The hand break is not on,can anybody help me on what to do to get the chain to turn while the engine is running.Thx
  • 2,176 Answers
First get a pair of gloves and try and turn the chain by hand with the motor not running, does it turn easily and if not I would check the chain tensioning and also for debris in the clutch area that caused the chain to come off. remove the side cover and make sure nothing causing it to hang up. Then put saw back together and retension and the way to do this is to hold up on the nose of the bar and tighten the screw until you can only lift the chain and barely see the drive teeth in the middle of the bar exposed, snug down the locking nut and again rotate the chain by hand, Also while checking everything out check the bar to make sure it didn't get damaged. Let me know if you need more assistance.
Posted on Mar 13, 2011
A brand new chain for chain saw is not cutting hat would be the problem?
A new chain may have to be sharpened to
the correct angles & cutting depth for your
saw
You can do that your self
Get the small tool that goes on the chain
& the proper diameter file, at a saw shop
Best if the chain is clamped into a vise & you
do 3 or 4 teeth, then move it along
You can do it on the bar, but it will be floppy to
do your filing
Chains are somewhat generic when made
Do you have the correct chain for your saw?
Nov 03, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What would cause a new chain saw not to cut
New chains stretch considerably and yours may have to be tightened frequently at first. The chain will not cut if there is too much slack.
It is possible the new chain was installed backwards.
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild thing saw brand new used once, over heating, not wanting to cut, why?
If there is no oil getting to the chain, you will have metal to metal contact between the chain and the bar with no oil film, the chain will look dry and be covered in baked on resin from the heat, make sure you have adiquate chain oil in the oil chamber, this chamber is seperate to the fuel chamber, it should be filled with a non fling chain oil.
Aug 28, 2011 | Poulan P4018WT Wild Thing 18Inch 40cc...
Lost my manual for my Poulan wild thing 2375 chainsaw and I want to fill it up with oil and fuel.
Fill the oil tank at the front of the saw with a non fling chain oil, or as thick an oil as you can get, fill the fuel tank with a 25-1 fuel oil mix, use a good, well known brand of two stroke oil designed to be used in chainsaws.
Jul 15, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 18" Poulan Pro Wild
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
May 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My chain keeps binding up, i get it back on, start running my wild thing and with in 10 seconds it binds up
Try putting a new bar on it. Sometimes during use the grove in the bar gets a kink in it. This will cause the chain not to move like it should. Also, the sprocket at the end of the bar can go bad also causing a malfunction.
Best bet!!!!!! Buy a new bar...
Aug 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw will not start
Possible sheared flywheel/crankshaft alignment pin. Remove flywheel check pin.
Jul 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT Logo
93 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
