Question about Dirt Devil Vacuums
Will not hold a charge - Dirt Devil Vacuums
  • 784 Answers
If it will not hold a charge - then I would say that the battery is weak,old and bad and needs to be replaced. there is also a chance that the charger ityself is not putting out enough voltage to totally charge the battery. use a volt meter to check the charger and see if it is putting out the correct voltage,, if it is at the right voltage - then replace the battery.
c...
Posted on Mar 13, 2011
Hand vac doesn't hold power
Mostly likely it needs a new power pack, but you could try cleaning off the contacts first. Use a pencil eraser and clean the metal power contact on the charging unit and the vacuum. Then charge it over night. If that doesn't help, charge the power pack.
Oct 15, 2014 | Dirt Devil Gator 18V Cordless Hand Vacuum...
Shark won't hold charge
How long are you letting it charge for? It's also possible the battery is defective, or there is a short in the vac.
May 26, 2012 | Shark Vacuums
Will not hold charge. do i need to buy new battery?
Hi make sure the unit is charging by checking it with a tester , i am not sure of the voiltage when charging but if you look on the charger it will have the amount it should be charging the battery, if it is charging and your battery is not taking the charge then replace the battery
Jul 27, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
The batteries will not hold a charge very long before it stops working.
Sorry to read about your problem, I hope this helps you out.
defective batteries time for new ones
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Vacuums
I think the battery is not holding its charge anymore. The red (charging) light does change to green but only runs a few yards on leaving the dock.
You have dead nimh (nickle metal hydride) batteries2_bing.gif.
You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Mar 04, 2010 | iRobot Roomba 560 Robotic Vacuum
Cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Jan 14, 2008 | Vacuums
Vacuums Logo
306 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
