My Emerson LD195EMX is flashing green, and red, and blue, and white and black. I plug it in and it automatically powers on, says digital television on the right hand corner of the screen, and immediately starts fleahing these different colors. None of the buttons work and the only way to shut off the television is to unplug it. It is a dvd combo t.v. When I put in a dvd it sounds like its reading and then spits the dvd back out.
  • 566 Answers
Hi Jamie, welcome to fixya
I have here a procedure that works well on Sylvania tv`s , since both brands/models are made by FUNAI , it may work on yours as well.
With the tv`s original remote control and in one sequence, press the arrow left then right and power.
As i said this works with sylvania but will it work on yours ????
Nothing to loose by trying i guess :)
I`d like some feedback on this if it does.
By the way this problem is known to occur after a power blackout or if the power cord or power bar is turned off while the set is playing.
Hope this help and good luck.
Posted on Mar 17, 2011
  • 9 more comments
  • jayh2o87ss Apr 24, 2011
    Yeah it worked for me. Mine was doing that color thing for a while now it works great thanks.
  • jnel6 Sep 20, 2011
    My Emerson LD195EMX is doing the exact same thing as jamie's is doing. If I have the original remote adn bought it off the net do I have to program it to my Emerson LD195EMX before trying you solution with the left,right, power combo? Thanks
  • Jacques Marin
    Jacques Marin Sep 27, 2011
    Yes it should work without any programming if it is the original or direct replacement,although i do have an addendum to that post, in some case you use the arrow up then down, unplug the power and back in again .
  • T. A. Goemans Oct 12, 2011
    Worked Great. Thanks so much. This saved my day.
  • Jacques Marin
    Jacques Marin Oct 15, 2011
    would like to make a correction on this;
    Instead of arrow left/right
    Try arrow up/down ,unplug tv and plug it back (power cycle)
    You may have better luck with that procedure.
  • carlos garcia Oct 15, 2011
    i have the same problem with the same tv only its not working, so let me get this strait. what do u mean by one sequence, do i press them all at once? do i press one at a time? or left arrow alone and the right and power at the same time? please help..
    Just want to say thanks it worked for me too.
  • Eiri Yuki Nov 12, 2011
    I have the same problem, but unfortunately I don't have the original remote. Is there some thing i can do about my tv still?
  • acmaxwell Nov 16, 2011
    Thanks! Worked great!
  • snogard77
    snogard77 Dec 04, 2012
    The up down unplug works with out the orignal remote
  • Trina Chappelle
    Trina Chappelle Jan 23, 2016
    Thank you so much worked like a charm!
    New Friend:
Thank u sooooo much this fixed my problem except i did up down power button off then on
Posted on Feb 16, 2014
  • 1 more comment
  • Tracie McGlin
    Tracie McGlin Dec 02, 2014
    Thank you so much for your feedback...my grandson tried to shut down my TV by himself and did God only knows what. I have been trying for two days to fix it and this was my last attemt. The up/down buttons worked for me as well.
  • Angela Briseno
    Angela Briseno Mar 20, 2018
    Up down power was good for emerson thank you sooo much!!
  • Larry Mar 20, 2018
    Glad this was brought up again, it works for all FUNAI TV's that have this issue and they include sylvania, emerson, philips, magnavox, RCA, funai, and later Sanyo set...I'm sure I'm forgetting some but that is most them
Im having the same problem i push the up and down at same time and unplug and nuthing please help me my kids lost the remote to the tv
Posted on Dec 07, 2013
  • 512 Answers
Your TV needs to be repaired, please take it to a TV technical service center.
Posted on Mar 13, 2011
  • Jacques Marin
    Get a life or a new job jose maria ,this is a simple test mode that the tv falls into, all you need is the correct procedure to get out of it.
RED GREEN AND BLUE
hi sound like epprom fault there's a memory chip installed on the main board of the tv sometimes these can cause this fault hope i'm wrong good luck
regards
shaun
Jan 25, 2014 | Emerson LD195EMX 19-inch LCD HDTV/ DVD...
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
I had my Emerson Tv since depraved of last year. I had moved and went to plug it in and it's flashing different colors. The colors are:red, green, blue, gray
With the original remote. Press cursor button up followed by cursor down. Power off TV. This should return your TV back.
Mar 11, 2011 | Emerson Televison & Video
Emerson tv dont work with xbox. can only hear audio but no video
IS THE THING PLUGGED IN RIGHT? YELLOW TO THE YELLOW, RED TO THE RED, WHITE TO THE WHITE? HOW ABOUT GREEN TO GREEN, BLUE TO BLUE, RED TO RED, WHITE TO WHITE?
May 12, 2010 | Emerson LC320EM8 32 in. LCD TV
TV FLASHES DIFFRENT COLOURS
The set could be in a demo mode.Wich brand is the set?
Jul 20, 2009 | Televison & Video
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Televison & Video Logo
3,472 people viewed this question
Top Televison & Video Experts
