Question about Microwave Ovens
How do you set the time on a pacini oven - Microwave Ovens
  • atulatelang Mar 13, 2011
    What is the model number of your Oven??
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
A time was set on the oven and it is the wrong time. i would like to change it.
Good afternoon Penny.
The manual for this microwave can be obtained/viewed here ( and have tips for all those other things like changing the scroll speed of the display )
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40536-1.pdf
If you go to to Page 24, the time set is a fairly common one:
  1. Press [Clock]
  2. Enter Time of Day with numeric keypad
  3. Press the [AM/PM/Scroll Speed] Button under the Zero key.
  4. Push [Clock] or [Start] to finish and set the time.
Cheers - hope this helps.
D
Dec 01, 2015 | GE Spacemaker JVM1740 1.7 cu. ft....
I dont know how to set the clock on the oven, therefore I cant start the oven
It depends on the make/model of the set.
All you need is to press and hold and the clock will blink on the hour/minutes and it must be changed and set. Use the button marked clock to press to hold for setting. Change time using the 0-9 key pads by typing the correct time..
Jul 23, 2011 | Microwave Ovens
When I set the time --- it just ticks and nothing comes on
Hello ebrunsw. Generally to set the time you push clock and then set the time AND then push clock a second time. Joe
Thanks for choosing Fixya!
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Goes to military time
According to the manual:
Press "Clock" pad once to set clock for 12 hour time clock
and
Press "Clock" pad twice to set the time for Military time.
I'm not sure what you mean by "goes to" military time.
Is that after you've already set it for a 12 hour time clock?
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
