Question about Venturer PVS8380 Player
My dvd player has a good dvd in it but it says it is loading and or no disc what is wrong with it
  • Venturer Master
  • 6,771 Answers
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it can not read the disc. The only option is to gently clean the laser lens with a Q-tip and rubbing alcohol and allow several minutes to dry, if this fails, cheaper to buy new than repair.
Posted on Mar 13, 2011
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
stonephoenix
  • 563 Answers
SOURCE: "Wrong Disc" error message
I work for COBY tech support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if you're getting that error message on every disk you try to play, it means the player has developed a problem in the dvd mechanism. This can't be repaired.
The warranty is 90 days from the day of purchase. A receipt would be required for warranty exchange.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
  • 460 Answers
SOURCE: when i put a dvd in the dvd player it loads and
it has a bad laser or will not read certain video farmats. most likely the laser in my dealings with proton. bye
Posted on Nov 09, 2009
  • 393 Answers
SOURCE: "Wrong disc" memorex dvd player error
Sounds like a build up of dust on the lens.
2 options -
Either buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
or second option is to remove lid from your player (usually 5 or 6 screws) and gently swab the lens with a cotton bud or similar soft lint free product. Try not to push too hard on the lens or you may damage the mechanism.
The lens is really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
Posted on Mar 02, 2010
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
Dvd player says loading then wrong disc
If it is disc made with a computer, you may need to convert the format to one that the DVD player is compatible with so it will recognize the disc contents.
Sep 22, 2009 | Coby TF-DVD7005 Portable DVD Player
Wrong disc?
to clean the lens you'll need to buy a lens cleaner.its a cd which cleans.so its no problem to load it.now if even the lens cleaner is not loading ,i suggest you bring it to a tech nearest you.
May 27, 2009 | Coby TF-DVD8107 Portable DVD Player with...
My N600D DVD shows wrong disc after loading
hi sometimes some dvd players will only play either -dvd or + dvd check your dvds and see what works best
Dec 18, 2008 | NexxTech N600D DVD Player
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
Wrong Disc
It is a bad data cable from the dvd head to the main board
Feb 14, 2008 | Coby TF-DVD7005 Portable DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Wrong disc
same problem. it worked for a couple of weeks. now every disc I put it, it says loading... then wrong disc.
Oct 15, 2007 | Coby TFDVD6200 Portable DVD Player
Loading but not playing
Try a firmware update
Feb 07, 2018 | Jwin JD-VD136
Venturer PVS8380 Player Logo
250 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
